Old 02-01-2008, 08:31 PM   #1 (permalink)
Date registered: Jul 2007
96 E320 weird problem
hey everyone ok im having this reallyyy wierd issue this started happening a couple months ago i left the car out in the snow for a couple of days and ever since then whenever it rains i get water drops all over the rear window in the inside and also the inside of the sunroof and its got that wet smell in the car and then i started noticing white stuff coming from the holes on the rear left seat i put some pictures to show what it looks like and lots of moisture in the sides of the inside of the doors does anyone have anyyyy idea why this is happening ive jus had way to many problems with this car any help would be really apreciated thanks alot
cameron07 is offline   Reply With Quote
Old 02-01-2008, 08:37 PM   #2 (permalink)
and also the white stuff on the seat just wipe it off with a napkin but it keeps coming back thanks
Old 02-01-2008, 08:52 PM   #3 (permalink)
raymond-'s Avatar
Date registered: Jan 2004
looks like manifestation of mildew. cause? hard to tell, but based simply on
what you have identified, condensation, leakage, gasket failure, plugged drain
vents....
try covering rear seat with plastic and see if it has collected drippings off the window/sunroof etc
raymond-
47º34'N 122º18'W
raymond- is offline   Reply With Quote
Old 02-02-2008, 05:40 AM   #4 (permalink)
Date registered: Jan 2007
Vehicle: 2005 S500 4matic Sport Designo
yikes, thats NASTY.
You need to check your rear window and sunroof seals ASAP
OliverK is offline   Reply With Quote
Old 02-02-2008, 12:26 PM   #5 (permalink)
the rear window and the sunroof seals seems ok to me but there is moisture around the sunroof seals should i just take it to a mechanic and show it to them?
Old 02-02-2008, 12:38 PM   #6 (permalink)
ohlord's Avatar
Per raymond
check all the drain lines.
Then pull up the carpet in the trunk and look for water,and also check under the seat by the battery for standing water.Get on it now,that mildew will take over and ruin that puppy
ohlord
If you can't find it quick,get ye to a shop that can.
ohlord is online now   Reply With Quote
Old 02-02-2008, 01:07 PM   #7 (permalink)
ive checked everything and i dont see any water and rite now theres lots of condensation on the windows and the sunroof and the nasty wet smell wich is pretty gross
Old 02-02-2008, 01:48 PM   #8 (permalink)
raymond-'s Avatar
my hunch is that it's well beyond your level of skill now and you should be
consulting with your insurance company or dealer for recommendation as
to how to proceed insofar (moisture/mildew abatement). each day you
leave this undone and the problem is magnified exponentially. i'm guess
that you have water damage which is into the hundreds if not thousands
of dollars. get off the computer and call someone....now.
Old 02-02-2008, 04:05 PM   #9 (permalink)
thousands easy.
That rear seat is toast.
Old 02-02-2008, 04:52 PM   #10 (permalink)
E430SportMB's Avatar
Date registered: Dec 2007
Vehicle: 2000 MB
THat could probably be solved by a simple chlorox. . . Mix with water and apply inside , out of leather but avoid metal parts. can cause rust. I hope it helps.
E430SportMB is offline   Reply With Quote
2004 E320...WOW!! Really weird things!! blah-blah W211 E-Class 8 09-17-2007 11:22 PM
Weird Turn Signal Problem W210 E320 Wagon rytsuru W210 E-Class 3 09-17-2006 04:54 PM
Weird Turn Signal Problem W210 E320 Wagon rytsuru W210 E50 AMG, E55 AMG 0 09-16-2006 12:14 AM
Weird shaking in my mom's 99 E320 gtran1502 W210 E-Class 3 08-28-2006 02:45 PM
Weird Oil Leak (94 E320 Wagon) Nugzar W124 E,CE,D,TD Class 2 06-13-2004 02:58 AM
