Old 02-01-2008, 02:54 PM   #1 (permalink)
UncleBenz's Avatar
Vehicle: E320 1997, Smart 2008
Send a message via MSN to UncleBenz
ABS & ETS warning-E320 1997
Hi guys,
Yesterday in heavy traffic the computer advise me a problem of ABS and after a problem of ETS.
Once I clear the messages, the yellow signals (bottom left of the cluster) stays on. This morning I started the car, runned but about less than a mile, it started again as above. I tried at lunch time, it did the same too.
I know that my ABS & ETS are not active when these warning lights are on.
But before going to my mechanic, can you please tell me what problem I have? Can I fix it myself "easely"? Is it expensive to repear? Etc.
Thanks in advance,
Uncle Benz
UncleBenz is offline   Reply With Quote
Old 02-01-2008, 03:41 PM   #2 (permalink)
Date registered: Nov 2006
Vehicle: 2002 e320
try resetting it by turning the steering wheel all the way to the right and then all the way to the left. do this a couple of times.
this worked for me when i got that warning message.
pvel is offline   Reply With Quote
Old 02-01-2008, 05:16 PM   #3 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
If it continues, replace the brake lamp switch. Get the part from the dealer, online or off; aftermarket brake lamp switches are junk and the dealer price isn't bad. This is a common problem.
Be sure to pull the plunger on the new switch all the way out before you install it.
Old 02-01-2008, 06:58 PM   #4 (permalink)
Date registered: Aug 2007
Vehicle: Mercedes
2nd the brake light switch extremely high failure rate
E4/// Turbo-unleashed
coastline is offline   Reply With Quote
ABS/ETS Warning Lights psmith V-Class 13 11-30-2007 02:19 PM
(ABS/ETS warning light) still on after replacing the Brake Switch jtorre1 W210 E-Class 4 08-08-2007 01:36 AM
ETS and ABS warning lights came off juicyicy W210 E-Class 3 05-20-2007 08:13 AM
ETS & ABS lights on garvard W140 S-Class 2 07-31-2006 12:19 PM
I found a fix for the ABS/ETS warning light Sandro N W210 E-Class 5 01-21-2005 11:29 PM
