Old 01-31-2008, 07:52 PM   #1 (permalink)
Date registered: Jan 2008
Vehicle: W210 1996 E320 Exterior Smoked Silver, Interior Mushroom
Help! I think I have screwed up something.
Hi,
left of the brake booster (#2) and unter the part #1 there is a cavity with several hoses. This evening I poked a vacuum cleaner tube in to suck out the dirt and leaves accumulating there. The vac tube must have touched a hose and some kind of oily liquid leaked out.
In order to check the leak I tried to remove the part #1 ( a plastic cover spreading from the wiper motor housing to the right fender), by removing a screw (#7) and lifting the clips 4, 5 and 6 but without success.
My questions:
1) what are the hoses there, transporting what liquid?
2) how can part #1 be removed (I already broke clip #6 )?
I'd appreciate your help, don't want to drive tomorrow to work with this leak.
Thanks!
My car is a 1996 E320 as in my profile.
W210 1996 E320 Exterior Smoked Silver, Interior Mushroom.
Bought Jan 2008 with 130K. Now 143 K miles as of 11/09/08.
texholdem is offline   Reply With Quote
Old 01-31-2008, 11:22 PM   #2 (permalink)
Big big screw-up
Hi again,
after being able to remove part #1 I could see the full extent of my predicament.
The small tube B connecting die hoses A and C thru the firewall is broken . Worse it seems B is only a affluent part sharing with another hose at the broken place. I am trying to access the broken location but the plastic undercover beneath D is in the way.
Questions:
1) What is part D, another coolant pump? (Edit: D is the motor for windshield wiper)
2) If I cannot provisorily mend the damage tonight (it will be a long night) can I stuff both ends of A and C and drive to dealership for repair?
Please help!
Old 01-31-2008, 11:35 PM   #3 (permalink)
Sandro N's Avatar
Date registered: Feb 2004
Vehicle: Hooked up 96 E320
Omg man, you have yourself a problem. Im not 100% positive but I think its a coolant line for the heater. Find a way to block it for the drive to your local mechanic in the morning. And dont use the heater. Good Luck
sandro natale
Sandro N is offline   Reply With Quote
Old 01-31-2008, 11:37 PM   #4 (permalink)
Sandro N's Avatar
Oh and to answer your last question. Yes, stuff them or block them however until you get it to the mechanic in the morning. Its probably not that serious..... Unless you take it to the Dealer!
Old 02-01-2008, 12:36 AM   #5 (permalink)
Thanks sandro for your input.
There is noway I can access the broken place behind the firewall at the location X, the plastic part under the wiper motor is one piece completely extends from fender to fender (from A to B in the picture); besides at the each far end there is a rivet R (not a screw) holding it down.
In the schematic below the break is between B1 and B2 and is at the firewall windshield side, while E is the other hose.
The part I need would be D, B (one part, some kind of Y connector), but the problem is how to access it.
Old 02-01-2008, 12:54 AM   #6 (permalink)
Sandro N's Avatar
How the hell did you jam the vacuum down there that hard anyway!
It might not be a part that is easily replaced considering its something thats not often broken, but maybe from under the car there is a better perspective. Take it to a guy that knows Mercedes, thats the most important part I think. Some guys pretend to know so you'll trust them into leaving the car so they can foot you the big bill at the end. It pays to know what your talking about if you know what I mean.......
Nice schematic by the way
Old 02-01-2008, 01:37 AM   #7 (permalink)
Hi sandro,
Thanks to follow up on me. I disconnected part A from the from of the firewall and stuffed A (pic) I suppose the coolant flow if from A to C, D right?
Provided A is well blocked, am I safe as long as I don't turn on the heat, that means I will turn the inside temp all the way down?
Thanks a lot!
Old 02-01-2008, 01:42 AM   #8 (permalink)
Sandro N's Avatar
Dont turn the climate control on at all. that wont stop the circulation of coolant from the lines, but It cant hurt. I wouldn't start bypassing any of the lines unless you can make a good connection. Just cap them off and drive to the mechanic.
Old 02-01-2008, 10:10 AM   #9 (permalink)
Part identified: It is the "pipe line" #23, the connector to #107 is broken. I blocked #5, that means no water for windshield washer. The part may be $10,- but it is inaccessible to me, unless I can remove many other parts like the brake booster or the panel under the wiper.
I am still not able to get to dealer for part. Had to go to the office first, will try to get out at lunch time.
At the moment the makeshift fix is:
1) hose #5 is pluggged with slight leak of vaporized coolant, I will loosen overflow reservoir cap to decrease pressure.
2) hose #14 and #107 are open.
The issue of accessing #23 remains unsolved unless either the big plastic panel or the brake booster is removed, of which the latter is more doable since the panel is riveted at both ends.
Any idea on how to remove the brake booster?
Thanks!
Old 02-01-2008, 07:36 PM   #10 (permalink)
Date registered: Apr 2007
Vehicle: 2001 SLK 320(96K Miles), 2002 E320 Special Edition(113K Miles)
Probably easier and better to just drill the rivet out.
Only two thing are infinite, the universe and human stupidity, and I'm not so sure about the former.
Albert Einstein
Honest politicians (and lawyers) are like UFOs. Most people believe that there must be some out there somewhere, but nobody has yet been able to prove their existence.
Kobus is offline   Reply With Quote
I think I've been screwed. prtdvl R170 SLK Class 4 08-28-2007 07:38 PM
I'm so screwed! :) AzimuthAviation W126 S,SE,SEC,SEL,SD,SDL Class 15 03-12-2007 06:37 PM
I screwed up... BETO W163 M-Class 4 12-31-2002 06:47 PM
Did i get screwed? mrhappy71 W210 E-Class 4 08-09-2002 10:32 PM
Am I being screwed here? Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 4 07-30-2002 11:54 PM
