Old 01-31-2008, 03:54 PM   #1 (permalink)
Date registered: Nov 2005
Vehicle: '99 E320
MB trans fluid deal
just got a case of (12) of MB trans fluid on ebay. It got here today. I paid $80 shipped. Part #is A 001 989 21 03 10 also says 236.10. It was made in Dec. 2007.
'99 E320 black
'87 Grand National 1 owner
sixbangr is offline   Reply With Quote
Old 01-31-2008, 06:52 PM   #2 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
THAT is a sweet deal. Same PN is $14.84/qt. at Autohausaz.com so you got it for less than half-price.
Wonder what truck the seller stole it off of?
Take care and enjoy the ride,
Greg
Meister Eckhart
Old 02-01-2008, 06:30 AM   #3 (permalink)
Sergio's Avatar
Date registered: Sep 2002
Vehicle: 1995 E320
I just paid $11.49 per qt a couple of days ago!
Sergio
'95 E320 SE
'99 ML430 (gone)
'01 E320 Wagon 4-Matic
'94 C280 (R.I.P)
Sergio is offline   Reply With Quote
Old 02-02-2008, 09:13 PM   #4 (permalink)
Date registered: Aug 2005
Vehicle: 2001 E320
Where did you get it from?
cerritos is offline   Reply With Quote
Old 02-03-2008, 08:16 PM   #5 (permalink)
Date registered: Jan 2008
Vehicle: W210 1996 E320 Exterior Smoked Silver, Interior Mushroom
How do you fill the fluid, thru the dip stick tube? and to what mark?
On my dip stick there are two marks, 30 and 80? should the fluid level between them?
I could not find any info on that in my manual.
Thanks!
W210 1996 E320 Exterior Smoked Silver, Interior Mushroom.
Bought Jan 2008 with 130K. Now 143 K miles as of 11/09/08.
texholdem is offline   Reply With Quote
Old 02-03-2008, 08:28 PM   #6 (permalink)
Date registered: Mar 2007
Vehicle: 1990 500SE
Trans fluid
Thanks!
There is a little more to it than that.The 96 and on tranny's according to MB were suppose to be life time tranny fluid, which now, according to info from MB is not reccomended.
I'm surprised that you have a dip stick and with nummbers to boot. Most tranny dip stick tubes have a plastic lock cap on them as they were life time fluid and did not need a dip stick to measure the tranny fluid.
Once you drain the fluid and remove the lock cap, you do put the new tranny fluid into this tube to refill, but there is a special dip stick you buy from e-bay or the dealer to measure the tranny fluid amount.
108Benz is offline   Reply With Quote
Old 02-03-2008, 08:56 PM   #7 (permalink)
As in the pix below you can see the dip stick partly drawn out of the tube (1)
more drawn out (2)
in full length (3)
and the marks >30 <|> 80< at the end (4)
Old 02-03-2008, 09:22 PM   #8 (permalink)
Vehicle: 1990 500SE
That's interesting Texholdem.
Most MB's of this vintage have a lock cap on the tranny dip stick unless the 96 320 is different. How long have you owned the car ?. Your tranny fluid may have already been changed out once before if you are not the original owner and a new type dip stick installed.
Old 02-03-2008, 11:10 PM   #9 (permalink)
I have owned the car since 3 weeks . Still learning everything about it.
So, anyone has same issue like me? How do you test the tranny fluid level?
Is there a test via instrument cluster?
Thanks!
Old 02-04-2008, 07:34 AM   #10 (permalink)
Date registered: Jan 2004
Vehicle: 1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL
I think about the '98 edition was first of the lifetime fill transmissions. Prior to that regular Dexron was the ATF recommended I think and 30K servicing too. Check your owner's manual to be sure.
Len
sokoloff is offline   Reply With Quote
Trans fluid benzover W208 CLK Class 6 09-09-2007 10:32 AM
trans fluid and diff fluid replacement cost? numitor R170 SLK Class 10 07-28-2007 10:40 PM
Which Trans Fluid to use pguard W202 C-Class 1 12-22-2006 09:52 AM
what trans fluid do i need? ross h W124 E,CE,D,TD Class 4 07-26-2006 12:55 AM
trans fluid benzmark23 W202 C-Class 3 06-24-2003 12:39 AM
