Old 01-30-2008, 11:35 PM   #1 (permalink)
E430SportMB's Avatar
Date registered: Dec 2007
Vehicle: 2000 MB
Wobbling sound on low speed . . .
Good day. I started experiencing this when I had a tire rotation and so I checked the tire pressure, they were all high. I lessened the pressure and it went away for a while and now its coming back little by little. Anyone who had the same experience? Please help.
I have been checking all 67 pages but have not encountered this topic yet.
The car, a 2k e430 sport. Thanks in advance.
E430SportMB is offline   Reply With Quote
Old 01-31-2008, 12:32 AM   #2 (permalink)
Premium Member
acarter53's Avatar
Date registered: Dec 2006
Vehicle: 2001 E430 Sport in Desert Silver and 2002 C320 Sport Wagon in Arctic White
Premium Member
Send a message via Yahoo to acarter53
Do you have directional tires?
E430 Sport
2001 E430 in Desert Silver with Sport Package, COMAND, Xenon Lights, Rear Sunshade, Heated Seats. Added K40 Stealth Radar, 30% Tint, XM Radio! www.premierbasement.com
acarter53 is offline   Reply With Quote
Old 01-31-2008, 01:32 AM   #3 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Hey, E. Assuming you didn't do the rotation yourself? Check the torque on your lug bolts. They could be too loose or worse, stripped (from over torquing) which recently happened to another member (and it was the hub that was stripped, a very dangerous situation and a pricey fix). Until you check that I would be very careful about driving it, but if you are close enough to the place that rotated them take it back and make them fix it, the iac that the issue arose following the rotation strongly suggests a causative factor.
Take care and enjoy the ride,
Greg
Meister Eckhart
Old 01-31-2008, 05:04 AM   #4 (permalink)
eric242340's Avatar
Date registered: Nov 2007
Vehicle: S320
This is a good point, look at the sidewall of the tyre and there will be a directional arrow, if the arrow is pointing towards the rear of the car then the tyre is the wrong way round. If no arrow then they are not directional tyres.
ERIC
eric242340 is offline   Reply With Quote
Old 01-31-2008, 01:44 PM   #5 (permalink)
Vehicle: 2000 MB
I have goodyear tires. I will check if they are directional. Thanks for the replies I do give value to them.
Old 01-31-2008, 02:06 PM   #6 (permalink)
gregs210's Avatar
If they are directional make the store put them back correctly and refund your money...and avoid them in the future.
And put their name in here so everyone else knows they are clueless morons.
Old 01-31-2008, 07:16 PM   #7 (permalink)
Vehicle: 2000 MB
Gregs210,
Actually, Goodyear offers free rotation , for as long as I am alive I guess, ha! ha! and . . . it is the Goodyear store on Mission in front of the Bayfair Mall. in San Leandro Cal. East bay. I will pay them a visit, soon.
Old 02-01-2008, 01:05 AM   #8 (permalink)
Sandro N's Avatar
Date registered: Feb 2004
Vehicle: Hooked up 96 E320
When tires wear out they loose some of their "smoothness" if I can say that. Their structural integrity starts to fatigue. E class is inherently sensitive to wheel shake and as Brabus put it sometimes has a "crashy ride". Just make sure the guys that balanced the tires didn't cut any corners and balanced them to 0. Good Luck
sandro natale
Sandro N is offline   Reply With Quote
Low speed wobble & high speed vibration AMG63 W124 E,CE,D,TD Class 5 06-10-2007 07:36 AM
Wandering at low speed SLKSport R170 SLK Class 12 12-13-2005 08:56 AM
side to side shake and wobble of the car at low speed and fine tremor at high speed rbatista4 General Mercedes-Benz 5 03-25-2005 04:51 PM
low top speed? ButteryBenz W201 190E, D-Class 4 12-07-2004 12:12 PM
Very low speed rumble ? Alan G-Class 3 12-22-2001 05:12 AM
