» Sponsor Links
»Garage Storage and Cabinets
Old 01-28-2008, 06:59 AM   #1 (permalink)
mpr2007's Avatar
Date registered: Jul 2007
Vehicle: 2001 E320 4MATIC, 210.082, 112.941, WDBJF82J61X051xxx
City Light Options
Hello all - quick question: Can LED lights be used to replace the "City Lights" or will this cause an issue with the bulb monitoring system? These are the H6W bulbs I'm referring to. I'm looking to find a bulb closer to the whiter/bluer Silverstar low/high/fog bulbs I am running. I did find Osram Cool Blue H6W bulbs at Motorbulbs out of England but would like to use LED if possible.
Thanks,
M
mpr2007 is offline   Reply With Quote
Old 01-28-2008, 08:49 PM   #2 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Thanks,
M
You can use LED but yes, you will have to use a resistor in the circuit to avoid the dreaded "Lamp Malfunction" warning.
Take care and enjoy the ride,
Greg
Meister Eckhart
Old 01-29-2008, 08:26 AM   #3 (permalink)
mpr2007's Avatar
Thanks for the info - couple more quick questions: Would the resistor go in series and what value/watt? I'd assume if it goes in series a 1/4 watt resistor would be sufficient since the LED current draw is much less than an incandescent bulb - but what resistance (ohm) would I need to trick the monitor?
Thanks.
Old 01-29-2008, 07:04 PM   #4 (permalink)
Date registered: Jun 2007
Vehicle: 2002 E320 4MATIC Special Edition, Black
A 10W 100 Ohm ceramic resistor worked for the lisence plate lights...hope that helps.
ajent420 is offline   Reply With Quote
DRL/City light help... DirtyMcDirt W203 C-Class 1 12-05-2007 01:44 PM
No City Light! benzbrit W208 CLK Class 4 09-27-2006 07:27 PM
City Light setup Strider W124 E,CE,D,TD Class 14 01-14-2006 08:54 PM
City light issue! weapon W208 CLK Class 2 01-13-2006 02:59 PM
LED city light esputmono W203 C-Class 2 05-23-2004 01:04 AM
