Old 01-26-2008, 08:28 PM   #1 (permalink)
covinsky's Avatar
Date registered: Dec 2006
Vehicle: 1999 500sl sport - 2001 e430 4matic - 2000 bmw 528i sport - 1966 corvette
Post console module & Diet Dr. Pepper
I have had my 2001 e430 4matic now for a couple of weeks and now my shifter console has acquired a taste for Diet Dr. Pepper, as a matter of fact, after its first few drops, it was show time. Now my e430 always shows me that it has a neat engine, by showing a me picture of an engine lit up on the dash! It also has a top speed of approx. 35-40 miles an hour, I guess it is to help save gas? I know these shifters are a nightmare when they have been wet, so now whats next, I've got the console off, down the bare shifter?
covinsky is offline   Reply With Quote
Old 01-26-2008, 08:35 PM   #2 (permalink)
Musikmann's Avatar
I don't remember the fix but there have been numerous threads on liquid spillage into the shift apparatus. If you don't get a timely reply, try the search function. Good Luck!
Old 01-26-2008, 08:53 PM   #3 (permalink)
Canyonero's Avatar
Date registered: Jan 2008
""Ok, now what's next?""
Howabout a closer look at where the soda went. If its into that electronics board consider removing it, cleaning it, checking it for shorts and reassembling it back into the shifter console.
PLEASE take a little while to do a little reserarch on ESD (electrostatic dipative) damage due to static. HANDLE THAT LIL BOARD WITH CARE, ITS FRAGILE AND EXPENSIVE.
when removing a component board get and ESD bag or 2 from radio shack and handle it accordingly to what you are satified with. Use a magnifying glass or better yet a microscope (yes, not everyone has one) to look over the board for shorts caused by the pop or blown resistors or capacitors. blown caps and resistors may appear charred, but they may not.
a MB scematic with values will give you the proper number values to check with the DMM. Outside of scematic value? possibly damaged by pop.
Secondly, scrub off any offending Dr. Pepper with a cotton swab and rubbing alcohol. let air dry. check the conectors with a DMM (digital multimeter) set to "beep" again looking for shorts.
Reassemble and see if it makes a difference? I dunno...
Since 1984:
1976 Pontiac Catalina
1976 Chrysler New yorker (Broughm)
1985 ford Tempo
1985 Chrysler daytona 2.2T
1986 Subura GL10 wagon
1997 Kawasaki KMX 200
1992 Honda accord
1996 Land Rover discovery
2002 Honda oddesey van
1995 GMC Suburban 1500 SLT
NEXT: MB E320?
Canyonero is offline   Reply With Quote
Old 01-26-2008, 09:49 PM   #4 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Up in the sticky is a link to a thread in the 208 forum. Basically blast the board -- generously -- with electrical contact cleaner and let dry. Disconnect the battery if you haven't already. Reassemble the board and console. Reconnect the battery, resolve the resets and radio code per the manual, cross your fingers and start it up. The testing reference is all well and good, but you already know it's the board.
Take care and enjoy the ride,
Greg
Meister Eckhart
Nokia E61i & SAP (v2) Bluetooth module pete Audio & Telematics Forum 20 01-12-2008 12:00 PM
Diet Dr. Pepper! Digmenow Off-Topic 11 10-13-2007 02:04 AM
Carbon console & door strips Johnblade R129 SL Class 1 10-05-2007 05:15 PM
problem with command console & v60i phone benltc Audio & Telematics Forum 1 12-30-2006 03:39 PM
Bluetooth Module & Nokia 6630 phone GL450owner GL Class 8 12-17-2006 02:33 AM
