Old 07-01-2008, 06:44 AM   #21 (permalink)
jlomon's Avatar
Date registered: Dec 2006
Vehicle: 2000 E320 4Matic Wagon, 1994 C280
Originally Posted by tirona View Post
engine wiring harness is not a problem on w210, only on previous years w124.
You could find this problem on all M104 equipped MBs from the 1993 to 1995 MY, with some spillover into early production 1996 cars. This includes W124, W140, W202 and on rare W210 (early production 96's). Also M120 equipped W140s (M120 is essentially two M104's joined at the crank in a V) in the same model range. They stopped manufacturing the bad wiring harnesses in 1995 but there were some left that made it into early 1996 cars. A 1997 W210 (as the OP has) won't have to worry about this.
jlomon is offline   Reply With Quote
Old 07-01-2008, 06:48 AM   #22 (permalink)
jlomon's Avatar
Originally Posted by texholdem View Post
2. What are the two golf-ball-sized holes on the engine head under the air inlet housing? Is the air fed thru them as well as thru the throttle body?
I believe they are for crankcase ventilation. Gasses would be sucked up through those two holes into the air intake in order to send them through the throttle body and into the cylinder again in order to combust them.
Old 08-06-2008, 05:48 PM   #23 (permalink)
Date registered: Jun 2007
Vehicle: 1997 E320
Doesn't the inline 6 use 12 plugs or have I been hearing wrong?
Down South is offline   Reply With Quote
Old 08-06-2008, 05:51 PM   #24 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Hey, south. Please click the user cp link and update your profile with vehicle and location info as that is quite useful.
The L6 is one plug per cylinder, the V6 is 2, so yes, you've heard correctly (even in the deep south they get some things right, ha ha), 6 for the L6 and 12 for the V6. There is a separate DIY for the V engines.
Take care and enjoy the ride,
Greg
Meister Eckhart
Old 08-06-2008, 06:41 PM   #25 (permalink)
Vehicle: 1997 E320
Greg
That means that I have been hearing wrong. You said the V6 is 12 plugs, right? I have been hearing that the inline 6 uses 12?!?!?!?!?
Old 08-06-2008, 06:47 PM   #26 (permalink)
ohlord's Avatar
Who have
you been hearing from,the m104 inline 6 has 6 the m112 has 12 the m113 has 16.Listen to someone who knows what they are talking about.
ohlord
ohlord is online now   Reply With Quote
Old 08-06-2008, 11:26 PM   #27 (permalink)
Vehicle: 1997 E320
ohlord
I actually wasn't listening to anyone, just something I heard thats why I came in hear and asked. Thanks for the info.
Old 08-06-2008, 11:49 PM   #28 (permalink)
gregs210's Avatar
Sorry, guess I misread your meaning. As I and ohlord noted, 6 for the L6, 12 for the V6.
Photo Diy- Spark Plug Change. G-AMG W210 E-Class 14 08-12-2008 03:11 PM
DIY: spark plug change C240 W203 DETANE W203 C-Class 2 06-24-2008 05:54 PM
Photo Diy-spark Plug Change, Part 2 G-AMG W210 E-Class 15 04-02-2008 02:06 PM
Photo Diy-spark Plug Change Part 3 G-AMG W210 E-Class 9 06-30-2007 11:26 AM
Photo Diy- Spark Plug Change-part I G-AMG W140 S-Class 0 02-27-2007 10:12 PM
