engine wiring harness is not a problem on w210, only on previous years w124. also when changing the spark plugs (F8DC4 only) on m104, don't forget to change the 3 connectors also, they cost like $12.
the whole job shoulnd't take longer than 20 minutes to someone who has done it before, and less then 1 hr to someone doing it for the first time. pretty easy job on m104, but it needs to be done every 30k miles.
Confused ! My Owner's manual (M104.995) says Bosch F9DCO and the Bosch catalog suggests Bosch 4301 Platinum 2+.
W210 1996 E320 Exterior Smoked Silver, Interior Mushroom.
Bought Jan 2008 with 130K. Now 143 K miles as of 11/09/08.
Dood, I don't know what brand of crack they have you smokin' up there, but don't send any out this way.
RubenCR, thanks for the post, you're now immortalized in the DIY sticky thread.
For those of you contemplating a spark plug change, while these are high voltage circuits (at least downstream of the coils), they're also completely dead so long as your key remains in your pocket. No need to disconnect the battery first.
Take care and enjoy the ride,
Greg
RubenCR, thanks for the post. I had been googling all week for this info as I have the same inline. Like "Gregs210" said, "you are immortalized in the DIY sticky thread".
page one of this post,remove the coils,remove the connectors,install new connectors when you replace the plugs.Use the correct plugs.No multi tip B.S. and no anti-seize on the plugs.
ohlord
connectors at autohausaz.com
