» Site Navigation
» Other Sites
Old 01-10-2008, 11:31 AM   #1 (permalink)
ProV1x
ProV1x's Avatar
Date registered: Jul 2006
Vehicle: E55 ///AMG
Will W210 wheels fit on W211?
I know that W211 wheels do fit W210 cars if you buy special lug bolts. Conversely, do W210 wheels fit W211 cars, with the right bolts..? Does anyone know exactly what spec bolts I'll need? thanks
Gone but not forgotten:
2003 Honda S2000
1999 BMW 540i sport
1995 BMW M3
ProV1x is offline   Reply With Quote
Old 01-10-2008, 11:40 AM   #2 (permalink)
gregs210
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Hey, pro.
Yes, they'll fit. Radusadirect.com (noted in the tips sticky!) has the custom lug bolts, unfortunately you'll have to determine length yourself. Measuring from the bottom of the ball seat through the wheel the bolt should extend about 3/4 to 7/8" past the mounting surface (that gives you the shaft length which is what Rad will need). One of those little pocket/keychain-type tape measures works well for this.
Take care and enjoy the ride,
Greg
Old 01-10-2008, 11:55 AM   #3 (permalink)
lkchris
Date registered: May 2005
Vehicle: '07 GL320CDI, '06 E320CDI
Originally Posted by gregs210 View Post
Hey, pro.
Greg
So you're saying a 14mm dia shaft bolt will go through the hole in the W210 wheel designed for 12mm bolts? Tight fit I bet.
Kent Christensen
Albuquerque
Old 01-11-2008, 06:29 PM   #4 (permalink)
gregs210
gregs210's Avatar
My OEM 210 wheels had quite large holes, there was lots of slop in there. I suppose I shouldn't make a blanket statement that any 210 wheel will be okay but 2mm isn't much in this league. When I was on the lesser forum there was someone who had done it and said they fit okay, not much play but it wasn't as though s/he had to ream the hole or anything.
In my work parking lot there are other employee cars that include a 202, 210 and 211 (E63, the lucky dog). Come next week -- and with the 63 driver's permission -- I'll pull one of his bolts and see if it fits in the 202 and 210 stock wheels.
Greg
Old 05-14-2008, 11:53 AM   #5 (permalink)
FrankiE55
Date registered: Mar 2007
Vehicle: 2001 E55
To clarify a little, the bolts shaft is still 12mm in diameter, the 14mm that you keep hearing is the radius of the ball seat.
W210 specs:
12mm shaft diameter
1.5mm thread pitch
12mm radius ball seat
17mm hex head
W211 specs:
14mm shaft diameter
1.5mm thread pitch
14mm radius ball seat
17mm hex head
FrankiE55 is offline   Reply With Quote
Old 05-14-2008, 03:41 PM   #6 (permalink)
gregs210
gregs210's Avatar
W210 specs:
12mm shaft diameter
1.5mm thread pitch
17mm hex head
W211 specs:
12mm shaft diameter
1.5mm thread pitch
17mm hex head
Um, Frankie I'm not sure where you got your spec, but the 211 hub is drilled and tapped for 14Mx1.5 bolts. Else my co-worker got the only one they did that way.
Greg
Old 05-15-2008, 06:45 AM   #7 (permalink)
FrankiE55
Vehicle: 2001 E55
i misread the topic, I went with the w211 wheels on my w210 car. I did go with rad as well.
Old 05-15-2008, 08:29 AM   #8 (permalink)
gregs210
gregs210's Avatar
It's too easy to misread all of those hieroglyphics. I did that a while back on this very topic. Sometimes you just go cross-eyed.
Any pics in our gallery or the AMG-210 one?
Greg
Old 07-01-2008, 10:43 PM   #9 (permalink)
arnel_lim
Date registered: Aug 2004
Send a message via Yahoo to arnel_lim
What Size Lugs Do I Need
I'm about to pick up a set of stock W211 wheels from my brother-in-law for use on my W210 (1999 E430). Can you clarify what lugbolts I need to purchase? From reading this thread, I presume my current lugs won't work. My brother-in-law says he still has his OLD lugs. I presume those won't work either, right?
arnel_lim is offline   Reply With Quote
Old 07-02-2008, 02:39 AM   #10 (permalink)
ohlord
ohlord's Avatar
Vehicle: 99 e320 wagon,bmw,vw,mgb,mg midget,subaru wagon
Call
Rad dude. Hit them up and they will do you Good.Just tell them what you have and say what you got?
W210 E-class wheels fit W211 E320 CDI? kkau W211 E-Class 9 11-06-2007 12:38 PM
Will W211 rims fit on W210? farsal W210 E-Class 16 06-23-2007 09:18 PM
W211 AMG seat covers fit W210? DominicArnold W210 E50 AMG, E55 AMG 3 05-04-2006 03:29 PM
Will W211 (from 2004 E320) wheels fit 02 W210 4matic? az2md W210 E-Class 2 02-13-2006 12:22 PM
W211 Wheels on a W210 islandiron W210 E-Class 6 08-25-2004 09:06 PM
