Old 01-09-2008, 06:33 AM   #1 (permalink)
TNTRower's Avatar
Date registered: Sep 2007
Vehicle: 1998 E320 Wagon
Smile How to make your Own Power Bleeder
Hi guys!
Well after some time here is the "how-to" on your own personal power bleeder for brake system. Thanks to Kajtek1 for the free brake reservoir caps. You guys will have to buy your own.
I have the document in Word Format and the pictures are much clearer. This PDF is a scan as I do not have the Acrobat software. If you want the clearer pics IM me with an e-mail addy and I will send it to you.
As always, I invite suggestions on how to make this better.
Drew
File Type: pdf How to make your own power Bleeder.pdf (693.4 KB, 214 views)
Who's John Galt.
"Timeo Danaos et dona ferentes" - Virgil, The Aeneid, Book 2
TNTRower is offline   Reply With Quote
Old 01-09-2008, 10:50 AM   #2 (permalink)
ohlord's Avatar
nice
work
ohlord
ohlord is online now   Reply With Quote
Old 01-09-2008, 05:56 PM   #3 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Digital Camera, $200.
Miscellaneous supplies, including a freebie like Monster Garage: $26 plus tax
A little time and perspicaciousness: zero dollars.
Gaining immortality with a TIPS/TRICKS sticky post on BW: Priceless.
Nice job, Drew.
Take care and enjoy the ride,
Greg
Meister Eckhart
Old 01-09-2008, 06:23 PM   #4 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/320cdi ML320/55
WOW. You really made professional tool.
How hard is to pump the sprayer to 35 psi?
I have one, but it has a piston gauge with no scale, so didn't want to spend that much time to convert it. The spare tire system was much easier.
Kajtek1 is offline   Reply With Quote
Old 01-09-2008, 06:49 PM   #5 (permalink)
TNTRower's Avatar
Thanks for compliment. Could not have done it without your help!
I don't know that I would do it much past 20 PSI. As for the 35 it is a whole lotta pumpin' to get it there. Just to get to 10PSI with one bottle of Brake fluid was about 15 -20 pumps.
Old 01-09-2008, 07:09 PM   #6 (permalink)
gregs210's Avatar
I think you know your next mod...more jb weld and a schrader valve (heck, you could do it off a "T" on your pressure gauge and save the jb weld).
Old 01-09-2008, 11:05 PM   #7 (permalink)
szk
szk's Avatar
Date registered: Nov 2007
Vehicle: MB E240 2001
Thumbs up Verry good job Man
thanks a lot
Tristan
szk is offline   Reply With Quote
Old 01-10-2008, 08:38 AM   #8 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
For making better PDFs, try this:
SourceForge.net: PDFCreator
It's a Windows printer that produces PDF files. It's free and works very well.
Old 01-10-2008, 10:29 AM   #9 (permalink)
uberwgn's Avatar
Date registered: Jul 2005
Vehicle: 2002 S210, 1999 E300
I've thought about doing this but am a little concerned about the safety of the plastic cap, fittings, etc. and the 2Bar of pressure required. I've got regulated air in my garage and the gage on the compressor is fairly accurate. I've found a source for the 45mm caps made from aluminum but they're $$$.
I've got the MOTIVE bleeder. It works well enough but takes a while to get it pumped up to bleeding pressure and then it leaks a bit, which requires more pumping. It's less than optimal for the MB cars.
uberwgn is offline   Reply With Quote
SLS Bleeder Foaming klaus560 W126 S,SE,SEC,SEL,SD,SDL Class 6 07-17-2007 10:05 AM
Brake Power Bleeder drewprof W126 S,SE,SEC,SEL,SD,SDL Class 4 06-25-2007 11:59 PM
power bleeder aggragated G-Class 1 10-15-2004 10:49 PM
brake bleeder w210 W210 E-Class 1 12-03-2003 01:15 PM
Has anyone used the "Power Bleeder" brake tool.... bgoin R170 SLK Class 16 01-23-2003 02:56 PM
