Old 01-04-2008, 07:36 PM   #1 (permalink)
Date registered: Sep 2006
Vehicle: E320 wagon 1998
Angry check engine electronics,very rough idle at start, shaky,scared to drive
I have no clue wheres the problem is, I have a 98e320 wagon .tomorrow my mechanic is going to change water pump which has been very shaky lately and maybe a fuel filter also, he mentioned some sensors might be faulty,but he doesn't have a computer, is there a way to check the codes from the car? has anybody experienced same problem?
jansa is offline   Reply With Quote
Old 01-04-2008, 07:41 PM   #2 (permalink)
ohlord's Avatar
where
are you located?A mechanic without a basic code reader?
post reply and we'll take it from there.
ohlord
ohlord is online now   Reply With Quote
Old 01-04-2008, 07:53 PM   #3 (permalink)
I am here in Florida, to say the truth his not a mechanic , his my friend from work, who has helped me with car issues before
Old 01-04-2008, 08:08 PM   #4 (permalink)
ohlord's Avatar
Go to
Harbor Freight Tools - Quality Tools at the Lowest Prices
pick up the 94169 obd2 code scanner for 39 bucks,they will match the internet price if you ask.Read the codes and post them.Do it before you tear into the pump or filter so you find out clues as to what is wrong one item at a time.
Let's see what codes read and take it from there.
ohlord
water pump diy when he is ready
mybenz - Tips and Howtos - Benz Repair and Maintenance Tips - W210 - Replacing Water Pump - by Faizalza
Old 01-04-2008, 08:47 PM   #5 (permalink)
thanks, you are awesome as always
Old 01-04-2008, 08:48 PM   #6 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Originally Posted by ohlord View Post
pick up the 94169 obd2 code scanner for 39 bucks,they will match the internet price if you ask.Read the codes and post them. Let's see what codes read and take it from there.
I agree you should get the codes, if you don't want to buy the reader them take the car to Autozone or Advance Auto and they will read them for free (don't accept their diagnosis, get the raw codes and search or post them). If you do want to buy it then print the web page; they told me they have to have that to put in the till.
If the reason your friend is replacing the WP is a blind stab at your issue and not because there are valid symptoms of its impending failure then STOP him. First rule: if it isn't broke, don't fix it. The shotgun approach will only waste money and may create additional problems.
Post the codes and we'll in from there.
Take care and enjoy the ride,
Greg
Meister Eckhart
Old 01-06-2008, 10:45 AM   #7 (permalink)
makarona78's Avatar
Date registered: Jan 2007
Vehicle: 2000 E320. 2002 745Li Lemoned, 2008 535i
Hi guys, I dont know why you changing WP , do you have a sign of leaks or your cluster shows low coolant level, If so then your water pum might be damaged , thats what happend in my car , i have the rough idle and shaking when i put it in the R gear Along with Cat ratteling ??, water pump has nothing to do with these symptoms
may be you need a new 02 sensors
makarona78 is offline   Reply With Quote
Old 01-06-2008, 11:56 AM   #8 (permalink)
gregs210's Avatar
Originally Posted by makarona78 View Post
... i have the rough idle and shaking when i put it in the R gear ...
Hey, Mak. I think we're all in agreement about the water pump not being the culprit for the OP's noted symptoms, but the part I cut above from your post would indicate blown motor mounts on your car.
Greg
Old 01-06-2008, 09:13 PM   #9 (permalink)
ok, we changed fuel filter, it was clogged , I been driving a car 40000 miles since I bought it(163000 mi now ), who knows when it was changed before me, and I forgot about it also,car starts with no problem now,disconnected the battery and "check engine light electronics" is gone ,rough idle is gone also,maybe it was due to unusually cold weather here 37F. Only my radio is now dead?I guess after I disconnected the battery. I don't know if it needs some codes ?also I went to advanceauto ,like you guys suggested, but theirs code reader didn't fit, well at least I can drive my car now, while I order one, to check whats going on at the waterpump, I don;t think its broken, its just where the fan and belt is I have a feeling its gonna come loose soon, it needs something but haven;t figure quiet out yet, thank you all for your input
Old 05-09-2008, 07:17 PM   #10 (permalink)
Just following up , we did change waterpump , since the belt and waterpump all broke on same day I received the part, amazing, what a coincidense, my car runs now much better
Rough Idle/no check engine light driver450190 W204 C-Class 2 07-27-2007 04:51 PM
Check Engine Light and Rough Idle tuRRtleSpeed W163 M-Class 4 03-13-2006 07:07 PM
Check Engine Light and Rough Idle tuRRtleSpeed W163 M-Class 5 03-09-2006 04:05 AM
Engine running rough when idle in Drive hawaiibeemer W210 E-Class 5 09-28-2005 03:19 AM
Rough Idle, Check Engine light, no problems? Derek R170 SLK Class 0 08-28-2002 12:57 AM
