Old 01-02-2008, 03:07 AM   #1 (permalink)
Date registered: Dec 2007
Vehicle: W210 E300D 1996
Transmission problem :(
Hi All!
First of all, sorry my bad english!
I have a little problem with my 1996 W210 E300D MB.
When i operate the kickdown switch, the time of the shift up more then 5 sec, and the engine just keep the higher rpm.
At normal throttle, it works fine, normal shift up.
The transmission oil, and filter is already changed, but a little bit more oil filled into the transmission (the oil state '80' on the oildipstick in cold engine).
Thanks for the answers!
One more time, sorry my terrible english.
Bye!
Megott
megott is offline   Reply With Quote
Old 01-02-2008, 04:40 AM   #2 (permalink)
Date registered: Sep 2006
Vehicle: 2004 CLK 240
Megott
I think that you have explained your problem clearly enough.
Normal driving - auto transmission works OK. When you kickdown there is a 5 second delay in the engine response.
I'm sure an Auto Transmission expert will be able to suggest something here. Unfortunately I'm no expert on AT.
It would be helpful to supply some more details about the car & the problem. e.g.
How far has this engine run? Is this problem there on both cold and hot engine? When did the problem start? All this information helps to diagnose a cause.
It's good for the forum also if you complete your own details. i.e, location, etc.
keyhole is offline   Reply With Quote
Old 01-02-2008, 05:10 AM   #3 (permalink)
More details
Hello!
Normal driving- Everything is OK, soft shift up and down.
But, (of course in hot engine and AT) when i operate the throttle more than "grandpa mode" or kickdown, the engine response immadietly, and run on the higher rpm, the transmission wait 5 sec in this higher state (i hear the engine almost burning away) and shift up very slowly.
I hope this is helpfull information.
Old 01-02-2008, 08:07 AM   #4 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
There are two input signals to your transmission. The first is the bowden cable, and the second is the vacuum to the modulator. If the vacuum is too great (low pressure), the shifts will be soft. I would check this.
Old 01-02-2008, 11:32 AM   #5 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Hi, megott, and welcome to the forum.
Your English is much better than my Hungarian.
I don't know if it would help but there is a reset procedure for the adaptive transmission. It's in the tips sticky but here is the direct link to it:
http://www.benzworld.org/forums/w210...omp-reset.html
Seems like that would be worth a try, good luck.
Take care and enjoy the ride,
Greg
Meister Eckhart
Old 01-02-2008, 12:06 PM   #6 (permalink)
Many thanks!
Keyhole, Matt L, Gregs210: Thank you the answers, i try and check it everything what you wrote.
Big thanx!
Best wishes!
Old 01-07-2008, 02:35 PM   #7 (permalink)
Hi All!
I change the transmission fluid and filter AGAIN, for a better quality oil and filter, i clean it the vacuum lines with high pressure air, check it the control cable and the throttle control.
And i try to reset my transmission (722.4)
Does't change anything
Tomorrow, maybe a try it a HandHeldTester, and read out the fault codes.
Transmission Problem heezyo2o R171 SLK Class 4 01-01-2007 09:57 AM
Is this a serious problem with transmission? Mr X W210 E-Class 13 11-13-2006 09:05 PM
help Transmission Problem david420sel W126 S,SE,SEC,SEL,SD,SDL Class 2 03-17-2005 02:06 PM
Brake padal vibration problem + transmission problem Majid Mansoori W210 E-Class 11 09-22-2003 08:33 PM
Transmission problem DarkCat W201 190E, D-Class 2 03-22-2003 10:48 PM
