Old 01-01-2008, 03:55 PM   #1 (permalink)
Date registered: Dec 2007
Vehicle: Mercedes Benz E420
Idle's High in Park Position
My 97 E420 idle's high in park position all of a sudden, currently I'm chasing a problem with error code P0455, I followed the DIY cleaning of purge valve but soon after the car started idling high and up & down. When the car is in drive its running smooth I'm ordering a new purge valve as we speak do you think this will correct this problem.
blackstarr777 is offline   Reply With Quote
Old 01-01-2008, 10:40 PM   #2 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
I think that code can also indicate a gas cap seal (try flipping the gasket) as well as the evap canister.
Have you done the "master reset" of everything? Sometimes that will cure some quirks. I'd try that before throwing any more parts or money at it.
Take care and enjoy the ride,
Greg
Meister Eckhart
Old 01-02-2008, 04:32 PM   #3 (permalink)
bmeister's Avatar
Date registered: Oct 2007
Vehicle: 1998 c230 non-compressor 98k at this time, a spring chicken :)
I would follow gregs210 advice, try the reset and then go from there, then re-check for codes, the gasket and the purge valve should not set you back though. Good preventative maintenance anyway
bmeister is offline   Reply With Quote
RPM to high when in Park MB7882 W202 C-Class 2 02-24-2007 01:43 PM
E320 only starts in Park the position johnsteve W210 E-Class 4 11-05-2006 01:25 PM
Park position of headlight switch Bluebird W123 E,CE,D,CD,TD,TE Class 5 01-07-2006 03:49 PM
Steering Wheel Position too high mb560sec W126 S,SE,SEC,SEL,SD,SDL Class 2 10-28-2005 03:18 AM
Truck can be turn off and key removed without gear selector being at Park position trong_l W163 M-Class 4 08-13-2002 05:32 PM
