Quick question - getting ready to do my first W210 oil change on my E430. I bought the oil (German Castrol), fleece filter and a composite filter wrench. I read that I need 76mm, 14-sided for the wrench.
The one I bought is the same as posted in the DIY here by Greg I think? It is a number 9 filter wrench.
My question is - I tried to put it on, but it seems very tight. It won't go on easily. It seems to be the right filter wrench from what I have read. Do these things need a little 'encouragement' to fit on? i.e. they are meant to be tight?
TIA.
Thanks Oliver. I did some more research and I think I have the wrong one. On the DIY here from Greg, he has the same brand wrench as me (FloTool Super Graphite) but his looks like a size 7. Mine is a 9.
I'll wait for Gregs210 to confirm.
What is exceptionally annoying is that these filters don't have the specs written on them - i.e. 76mm, etc. Only a manufacturer-specific size number.
I don't think any of the auto stores I've visited carry the number 7 in stock, figures...
BB PM'd me, essentially what I told him is that the chart for my car showed a couple of different wrenches based upon diameter (74 or 76 as I recall) and flute count. That led me to suspect that there may be some variance in what MB grabs from the parts bin, or that the wrench manufacturers aren't really sure. In any event I went and measured mine and then counted the flutes, confirming those numbers in the store at the time of purchase.
FWIW, it's a firm fit, but can be pushed on and off the housing by hand. If it is tighter than that I'd suspect that it is either the wrong diameter or the wrong flute count.
Take care and enjoy -- the ride in the NEW YEAR!
Greg
