Old 12-29-2007, 08:43 AM   #1 (permalink)
Date registered: Aug 2005
Vehicle: 2001 E320
Black Lines On Brand New Fleece Oil Filter
I purchased a brand new MANN fleece oil filter HU 718/5X from antohausaz. After I received it, I found out that it has two short black markings on the filter. I wonder what's that for?
cerritos is offline   Reply With Quote
Old 12-29-2007, 08:55 AM   #2 (permalink)
Date registered: Jan 2007
Vehicle: 2005 S500 4matic Sport Designo
I had the same on mine. I threw it in with no issues.
OliverK is online now   Reply With Quote
Old 12-29-2007, 09:02 AM   #3 (permalink)
Vehicle: 2001 E320
I just found out that there is an installation illustration came with the filter. There are four pictures on the paper but no words. I think what it's trying to say is that when the filter is correctly inserted on the "stick", there should be only one line exposed. If both lines are exposed, then the filter is not inserted fully.
I had experience that the filter is very difficult to be inserted fully at the last quarter inch or so. But I know that when I torque the whole assembly onto the engine, the filter will be pushed into the correct position.
Old 12-29-2007, 10:05 AM   #4 (permalink)
jlomon's Avatar
Date registered: Dec 2006
Vehicle: 2000 E320 4Matic Wagon, 1994 C280
That is exactly what the lines are for. If you have a little trouble sliding the new filter in to place. you can always try rubbing some fresh oil on the hole with your finger before sliding the filter into the canister lid. It will help the filter slide into place. Use a good amount of oil.
jlomon is offline   Reply With Quote
Why 5 o-rings with MB fleece oil filter? jpuzas W211 E-Class 5 09-07-2007 09:14 AM
Fleece Oil Filter? benz_driver W211 E-Class 29 05-07-2007 10:09 PM
Fleece Oil Filter Information... E 320W ClassAct W210 E-Class 2 09-21-2006 08:29 PM
The mystery of the "Fleece" filter turbofroggy W210 E-Class 6 12-03-2005 04:42 PM
Fleece Oil Filter Question Darkmann W163 M-Class 8 09-01-2005 01:38 AM
