» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Old 05-20-2009, 08:46 AM   #31 (permalink)
iluvjesus's Avatar
Date registered: Jan 2009
Vehicle: 2000 E320AV RWD
Thanks Matt, when I turn off the car and hit the rest button, the side vents blow again, not that warm though. I have the following questions.
1. I know duo valve DTC should be 1417 and 1418, but could the duo valve blockage cause DTC 1416? I am hoping it can because this is an expensive part.
2. When I remove the aux coolant pump for test, should I clamp those 2 hoses or just let the coolant flow and add back some later?
3. Any tricks on removing the clips/clamps on the hose? Do I have to break them?
Thank you.
Just for reference:
iluvJESUS_______Blog
"I am the Alpha and the Omega," says the Lord God,
"who is, and who was, and who is to come, the Almighty." Revelation 1:8
iluvjesus is offline   Reply With Quote
Old 05-22-2009, 08:45 PM   #32 (permalink)
Date registered: Oct 2007
Vehicle: 1996 E300D
Originally Posted by Matt L View Post
Absolutely you should. The 124 auxiliary water pump, when it goes bad, will burn out its climate control unit. I haven't heard of this on the 210, but maybe that's just because the 210 is a newer car and they haven't been failing much yet.
The W124 and later models CCU is internally current-limited; it won't burn out if the aux coolant pump seizes. It's the W123 CCU that is at risk; owners should fuse the pump (1-2 Amps max).
Our all-biodiesel family
1985 300D-T ex-California (W123) 232000 miles FOR SALE
1987 300D Turbo (W124) 148000 miles
1996 E300D (W210) 262000 miles
1988? Satoh Beaver garden tractor
Jeremy5848 is offline   Reply With Quote
Old 05-22-2009, 09:21 PM   #33 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/ML320/Audi A4 quatro
I had that pump bad on W210 and it is using magnet as a clutch. Meaning frozen pump will not freeze the motor. I know that the recirculating pump in ML runs some time after turning off the ignition to eliminate "hot spots" in the engine. Haven't notice that in E, but after being married for more than 1/4 of Century I don't hear everything anymore.
Kajtek1 is offline   Reply With Quote
Old 05-23-2009, 09:00 AM   #34 (permalink)
iluvjesus's Avatar
I tapped on the aux pump motor, and it works intermittently. I suspect the graphite brushes are gone, is it possible to fix it? Or I have to replace a new one, it is an expensive part. Thank you for your advise.
Old 05-23-2009, 09:05 AM   #35 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
That's good to know, Jeremy. I wasn't sure, but I also haven't heard of the problem in a 210.
Old 05-23-2009, 10:39 AM   #36 (permalink)
Kajtek1's Avatar
Those pumps are not serviceable. I hesitate to spend $200 + for a new one as well, but was able to find used one on junk yard. Not too many older pumps have triple hose for windshield fluid heater, but I found one on older S class. Than you can just plug the extra hose and use pump from other models. As far as I know you don't get too much freezing in HK ?
Old 05-23-2009, 10:57 AM   #37 (permalink)
iluvjesus's Avatar
Thanks again KT1, no freezing in HK at all. I will take your advise and look for one in the junk yard. Thanks for telling me other models' pump would work too. My I ask, when you replace it, do you clamp the hoses or just let the coolant flow and refill later?
I need your help on duovalve jansa W210 E-Class 2 06-21-2007 08:23 PM
MAS Removal and Cleaning Fallbangskid W210 E50 AMG, E55 AMG 5 04-09-2007 10:28 PM
A/C & duovalve sokoloff W210 E-Class 1 09-29-2005 07:24 AM
Headlight lens cleaning/removal Guest (MBNZ) W210 E-Class 2 02-23-2002 02:30 PM
Cleaning WSA 2000 a breeze, quick removal, just used wet towel, and supplied cloth, cleanasawhistle Jason Y R170 SLK Class 0 06-13-2001 07:28 AM
