» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Old 05-19-2009, 07:32 PM   #21 (permalink)
raed_jan's Avatar
Date registered: Apr 2008
Vehicle: '07 ML350 Tan Met, '99 E320 Obsidian Black Met, '89 190E 2.6 Blue-Black Met
Originally Posted by iluvjesus View Post
But now I have 1416, not sure it's new or old. I need Greg's code reader.
ILJ, would it help with Euro spec cars (as maybe yours is)
I love my W201
A wise man says "Nothing is more expensive than a cheap MB"
raed_jan is offline   Reply With Quote
Old 05-19-2009, 07:39 PM   #22 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
The climate control system is not accessible from the OBD-II port. Only through the 38-pin diagnostic port using SDS or Carsoft or such, or the pushbutton unit if you have one.
Old 05-19-2009, 07:41 PM   #23 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
^^^^^ What he said, if you have the pushbutton HVAC system, then use the GREAT built-in diagnostic that is explained in the stickies.
Old 05-19-2009, 07:54 PM   #24 (permalink)
iluvjesus's Avatar
Date registered: Jan 2009
Vehicle: 2000 E320AV RWD
I tried to press and hold both Autos and then the code reappears. So now I must check the coolant circulation pump.
iluvJESUS_______Blog
"I am the Alpha and the Omega," says the Lord God,
"who is, and who was, and who is to come, the Almighty." Revelation 1:8
iluvjesus is offline   Reply With Quote
Old 05-19-2009, 07:57 PM   #25 (permalink)
iluvjesus's Avatar
I don't know, but thanks. I think now I have new job to do
Old 05-19-2009, 07:59 PM   #26 (permalink)
Absolutely you should. The 124 auxiliary water pump, when it goes bad, will burn out its climate control unit. I haven't heard of this on the 210, but maybe that's just because the 210 is a newer car and they haven't been failing much yet.
Old 05-19-2009, 09:56 PM   #27 (permalink)
iluvjesus's Avatar
Sorry Matt, how do you check the coolant circulation pump?
Old 05-19-2009, 10:36 PM   #28 (permalink)
Now that's a very good question. It would be nice to have a pair of connectors so that you could easily wire a meter into the line, but that's a bit much to ask most times. What you want to know is the current demand from the motor. I don't know offhand what it should be, but not a lot more than one amp.
Old 05-20-2009, 12:34 AM   #29 (permalink)
iluvjesus's Avatar
Thanks Matt, is the motor always on, or should I check when temp >80C?
Old 05-20-2009, 08:24 AM   #30 (permalink)
It's not for cooling the engine, but for heating the interior. Turn the car off and hit the REST button.
I need your help on duovalve jansa W210 E-Class 2 06-21-2007 08:23 PM
MAS Removal and Cleaning Fallbangskid W210 E50 AMG, E55 AMG 5 04-09-2007 10:28 PM
A/C & duovalve sokoloff W210 E-Class 1 09-29-2005 07:24 AM
Headlight lens cleaning/removal Guest (MBNZ) W210 E-Class 2 02-23-2002 02:30 PM
Cleaning WSA 2000 a breeze, quick removal, just used wet towel, and supplied cloth, cleanasawhistle Jason Y R170 SLK Class 0 06-13-2001 07:28 AM
