Has any one ever used ATE Super Blue Brake Fluid in the Merc? When they serviced my E320 they used OEM. I have used this in my old BMW, but was curious if anyone is using this is there MB? Lately I have been in a lot of stop and go traffic and I noticed the brakes seem a little soft after awhile? Any thought would be appreciated.
2001 Black E320
2005 Kia Spectra5 (Korean Suburban) Wife's car
1994 BMW 325i Coupe (Gone but not forgotten)
1989 VW Jetta Wolfsburg Edition (Stolen)
1967 Porsche 912 (1st-Car) Still running
Reason: added link to ATE Super Blue Product Info
We'll I sure hope they did, it was at the dealership here in town. The has always treated me good. It's only been 2100 miles since the service, I will call them in the morning and have them re-check it. I was thinking that maybe there was some air in the lines, but was hoping for the best.
I have used Ate fluid for years but never liked the blue one just because it will not show the dirt and dissolved rubber as it ages as clear or yellow tinted one does. I try to follow the old Mercedes rule: "replace brake fluid once a year, preferably in the spring."
OEM is probably Ate or Pentosin.
Next time I'll be trying DOT 5.1.
Cheers
“Design embodies the values of a company. Even if there were no star, the car must always be recognizable as a Mercedes-Benz.” Peter Pfeiffer, Daimler AG
wow, replace it once a year? is there an easy DIY, wouldn't want to have to pay for this on an annual basis? i got my car a year ago and they did service the brake fluid before i bought the car, so maybe in the spring i'll give it a go.
2002 E320 4matic, black on beige, 95K w/ 17" sport rims
I used oil extractor to help flushing the brakes. With ABS it will not create enough vacuum to flush, but it will catch the fluid coming when you push the pedal and hold the air from going in. Pressure bleeder might be nice toy, but expensive and I have mixed feeling about pressurizing old fluid reservoir to 35 psi.
Can you squeeze toothpaste tube?
just kidding. The biggest problem with brake flushing is removing the wheels and cracking the bleeder loose. It is usually 8 mm hex, that is easy to screw if you don't have good quality wrench. With pressure bleeder the actual flushing is kids play.
