» Site Navigation
» Other Sites
Old 12-04-2007, 11:22 AM   #11 (permalink)
ohlord's Avatar
Vehicle: 99 e320 wagon,bmw,vw,mgb,mg midget,subaru wagon
bleeder
with fittings on sale at harborfreighttools comes with instructions.
use the oe rec fluid dot 4 or what ever.
Old 12-04-2007, 12:02 PM   #12 (permalink)
ohlord's Avatar
mercedes
rule is replace every TWO years preferably in the spring.Using the proper dot mb spec fluid.
Old 12-04-2007, 12:32 PM   #13 (permalink)
G-AMG's Avatar
Date registered: Oct 2005
Vehicle: '04 G55 '80 280GE '99 S420 '98 E320
Someone was asking about a DIY. I did one for the W140. Not EXACTLY the same,,,, but you'll get the idea.
http://www.benzworld.org/forums/w140...ht=brake+fluid
I would strongly suggest POWER BLEEDING (as per WIS), instead of VACUUM. There is a greater change of causing bubbles in the system by "sucking" rather than "pushing" the new fluid through the lines.
Also, I know many who advocate (including me) changing the fluid EVERY spring, especially if you live in a humid environment. It is such an easy, quick, job.... and since the cost of ABS parts are astronomically expensive, why take the chance? But, this is just my .02.
G-AMG is online now   Reply With Quote
Old 12-04-2007, 12:51 PM   #14 (permalink)
Kajtek1's Avatar
Vehicle: 300D/TD, ML320/55
I'd say the humidity is crucial word here.
Living in CA I have no problems driving with 10-years old brake fluids.
Kajtek1 is offline   Reply With Quote
Old 12-04-2007, 01:27 PM   #15 (permalink)
ohlord's Avatar
he's
the guy
Old 12-04-2007, 02:22 PM   #16 (permalink)
Date registered: Aug 2006
Vehicle: 1999 E300DT
Originally Posted by Big"D"inTheMB View Post
Has any one ever used ATE Super Blue Brake Fluid in the Merc? When they serviced my E320 they used OEM. I have used this in my old BMW, but was curious if anyone is using this is there MB?
I use it in my '99 E300, my '82 320i, and my '05 Pathfinder. Great stuff. I change it out every two years using the TYP 200 (same fluid but an amber color). Makes it easy to see when the old stuff has run through.
1982 320i
1999 E300DT
2005 Pathfinder LE
Dave1965 is offline   Reply With Quote
Old 12-05-2007, 04:17 AM   #17 (permalink)
Franasia's Avatar
Date registered: Jan 2005
Vehicle: 2000 E320S4 210.282
G-AMG:
I've used your procedure for years and found the British made Eezibleed unit is great. You need to use the spare tire for pressure but the unit itself is very compact. It also comes with the Ate type cap adapter for our cars.
This is in my view a very easy and cheap DIY job and the most rewarding since you can really feel the difference in the brake pedal. I feel the updated two year interval is toooo long for me.
Cheers
“Design embodies the values of a company. Even if there were no star, the car must always be recognizable as a Mercedes-Benz.” Peter Pfeiffer, Daimler AG
Franasia is offline   Reply With Quote
Old 12-05-2007, 06:45 AM   #18 (permalink)
Date registered: Jan 2004
Vehicle: 1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL
You can get a pressure bleeder for $30 to $40 or build your own for less. Until you've used one, I can't tell you how nice it makes that job. Driving around with ten year old brake fluid is not a good thing. Not only is your brake system probably less efficient than it should be, but maybe more importantly you are allowing moisture contaminated fluid to lay in your system. This WILL eventually lead to failure of something in your brake system, be it a master cylinder, a booster or the ABS unit. It's a whole lot cheaper to change your brake fluid every two years than to have to replace an ABS unit in ten.
Len
sokoloff is offline   Reply With Quote
Old 12-06-2007, 12:17 AM   #19 (permalink)
Big"D"inTheMB's Avatar
Date registered: Jun 2007
Vehicle: 2001 E320, 1967 Porsche 912, 2005 Kia Spectra
Thanks for the input, I had the dealer flush the system. The where more than happy too. Didn't even charge me, and I got a Latte. Brakes feel noticably better. I think everyone should be conscience when it comes to proper services being done on time.
"whatever dawg; I'm hungry"
Big"D"inTheMB is offline   Reply With Quote
Old 12-06-2007, 08:37 AM   #20 (permalink)
Kajtek1's Avatar
I know how hard it is to believe in something you have never seen in your life. I grew up in 4-seasons, where cars have been totally corroded in 5 years. Now after couple of decades in CA I still get surprised how big difference the weather makes. 30 years old cars with no under-body protection and no rust damage?
Driving diesels in CA took me several years of wasting my time observing water separators for moisture before I learned that the moisture accumulation in CA simply never happens.
So I feel for the guys who have to change the brake fluid every 2 years and deal with other moisture-related issues.
Brake Fluid change Wil_AMG R170 SLK Class 3 07-30-2007 08:04 PM
Newb Brake Pad Change, Now Brake Fluid Leaking Jeff619 W126 S,SE,SEC,SEL,SD,SDL Class 10 06-20-2007 05:54 PM
Brake fluid change. Easty R171 SLK Class 7 04-15-2006 06:45 AM
Brake Fluid Change satxmerc01 W210 E-Class 4 06-25-2005 11:41 PM
brake fluid change tabo W163 M-Class 2 04-24-2002 07:48 AM
