» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Old 08-08-2009, 02:43 PM   #11 (permalink)
Date registered: Oct 2008
Does anyone where the fuse id for the cigarette lighter - 2000 E320 4matic wagon?
Klypher is offline   Reply With Quote
Old 08-08-2009, 04:27 PM   #12 (permalink)
iluvjesus's Avatar
Date registered: Jan 2009
Vehicle: 2000 E320AV RWD
In previous models, it is the same as the Radio, so it is number 5 of the fusebox under the rear seat. Any problem with the cigarette lighter?
iluvJESUS_______Blog
"I am the Alpha and the Omega," says the Lord God,
"who is, and who was, and who is to come, the Almighty." Revelation 1:8
iluvjesus is offline   Reply With Quote
Old 09-24-2009, 09:53 AM   #13 (permalink)
Premium Member
Date registered: Aug 2008
Premium Member
My horn/fanfare doesn't work. Does anyone have an idea where to find the fuses for the fanfare (horn) on a 2000 E320 wagon. Chart in the fuse box on the driver's side of the engine compartment says they are #40 and #41. But there is no #40 and #41 in that fuse box. The horn mounted in front of the radiator works as I checked it by direct connect to the battery. The other horn I understand is mounted below the pax side headlight and requires bumber facia removal. That seems daunting to me. Anyway I guess next step to find out why the horn doesn't work is the fuses. Then the I guess its the switch in the steering wheel. You guys somehow always come up with an answer. I guess all MB issues are the same.
Thanks for all the previous assistance.
Dave
keywasted is offline   Reply With Quote
Old 09-24-2009, 01:00 PM   #14 (permalink)
Premium Member
Premium Member
Well out of frustration and because I was passing the local MB dealer I stopped and asked the female service manager where fuses #40 and #41 for the horn were. After 10 minutes of no luck a tech happened by and lo and behold they are in the driver's side engine bay fuse box. But, they are cleverly comoflaged in that the numbers are not black. The service mgr. and I both thought they were spares. If you look very closely you can make out the numbers in black on black. The 7.5 fuse was bad and the horn is back to working. Thanks to all previous inputs on this subject as in the treasure hunt for the fuse I learned even more about my car.
Old 09-24-2009, 09:05 PM   #15 (permalink)
iluvjesus's Avatar
Horn fuse should be in the control model box, which is behind the engine firewall opposite to the brake drum. There is a video clip in the general sticky DIY thread that explain where it is.
Has anyone got a list of what all the fuses serve?? pberrey V-Class 2 06-25-2007 01:25 PM
Barrel Fuses vs. MB Strip Fuses 94Wagenmeister W201 190 Class 0 09-25-2006 07:09 PM
list of fuses Thomas J W126 S,SE,SEC,SEL,SD,SDL Class 4 09-02-2005 05:07 AM
list of fuses seaman W210 E50 AMG, E55 AMG 0 01-31-2005 10:55 PM
Fuses list azohar W124 E,CE,D,TD Class 2 09-15-2004 03:51 PM
