I see the forum is active as usual.
I hope you are all getting excited about Christmas season that's just around the corner.
Anyhow, what would you recommend for tyre pressure? Both front and rear tyres.
If you are using a different size wheel & tire than stock, will the same tire pressure apply?
Thank for your help.
1999 E320 upgrade:
Sound: Nakamichi CD-400 Head Unit | Rick Reus System
Wheel & Tire: ASA 19" ZR2 19x8.5 F & 19x9.5 R | (It is currently waiting to be replace with 18" stagger. 19" rub the fender... sad. New setup should be here next week).
Brake: Goodridge G-Stop Brakeline Kit w/ Synthetic Oil | Brembo Cross drilled Rotor
Suspension: Belstine Sport Shock | Eibach Pro-Kit Spring | H&R F&R Sway Bar | Replaced rear constant velovity axles
Esthetic: 20% Tint Huper Optik Ceramic
For a car that's used for commuting, the pressures specified in your MB owner's manual are fine. For performance driving, there are better options available. Here's a webpage from Signal to Noise that talks about tire pressure.
