» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Old 12-04-2007, 09:49 AM   #11 (permalink)
fju2112's Avatar
Date registered: Nov 2005
Vehicle: 2002 E320 4Matic, 107K miles as of Jan 2009
yeah i have had that problem intermittently but not for quite a while now. in fact i think that only happened once w/ this car...
by pass side do you mean it's accessed on the interior or via opening up the hood? just curious.
2002 E320 4matic sedan, black on beige ("sport" package - bird's eye maple trim, 17" sport rims), 108K miles
RIP: 2000 E430 4Matic fully loaded - totaled 12/9/2006
Wife's car: 2000 Lexus ES300, Platinum Edition, 98K miles
http://drivingenthusiast.blogspot.com
fju2112 is offline   Reply With Quote
Old 12-04-2007, 01:51 PM   #12 (permalink)
Date registered: Aug 2007
No special tools are required. No machine shop work either. I used all the original parts inside the valve. The only thing new is the pop rivets, available at any home depot, auto parts store.
gt4rcdude is offline   Reply With Quote
Old 12-04-2007, 02:10 PM   #13 (permalink)
ohlord's Avatar
Vehicle: 1999 E320 Wagon,2000 E 320 Wagon, MGB Track/Rally, 94 Subaru Wagon ,1988 300E ,more....
engine comp
up by the firewall just in front of the black cover that has a label listing some engine specs and a/c charge specs,find that and then just move your eyes toward the front of the car a bit and you will see the two valve cans in that open recess.Most times a firm whack with a handle of a screw driver will free them up if they are sticking and the drivers side is warm and the pass side is cool with the a/c on.
Old 12-04-2007, 03:02 PM   #14 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Hey, FJ, look in the removal/cleaning DIY I just freshened, there are pics (worth a thousand posts, er words, right?).
Or I still have the link to the pics, so here's one that will help you ID it:
Take care and enjoy the ride,
Greg
If we ever forget that we are one nation under God, then we will be a nation gone under.
Ronald Reagan
Old 12-04-2007, 05:11 PM   #15 (permalink)
fju2112's Avatar
awesome, thanks guys!
Old 12-27-2007, 06:49 PM   #16 (permalink)
sidmon's Avatar
Date registered: Sep 2007
Vehicle: 1989 190D 2.5 non-turbo
After taking my duovalve apart on my W210 E420 for a clean up I noticed one of the valves had a broken stem. Tried 5 times to glue it but as soon as it was entered into the duovalve and then put back together it would snap again!
sidmon is offline   Reply With Quote
Old 08-06-2009, 04:39 PM   #17 (permalink)
Vehicle: '01 E430 4Matic
I took apart the duovalve and I didn't see any damage on the valves. There were a few small (1/16" to 1/8") brown chips that looked like plastic so something must be wrong but I couldn't find any damaged part. The stems were in place and everything else was clean. I'll have to take it apart again for another look for chips on the stem.
Joe_nj is offline   Reply With Quote
Old 08-07-2009, 09:19 AM   #18 (permalink)
iluvjesus's Avatar
Date registered: Jan 2009
Vehicle: 2000 E320AV RWD
Can you take some pictures for us to have a look as well? Thanks Joe.
iluvJESUS
"I am the Alpha and the Omega," says the Lord God,
"who is, and who was, and who is to come, the Almighty." Revelation 1:8
iluvjesus is offline   Reply With Quote
valve stem question vdubpower W126 S,SE,SEC,SEL,SD,SDL Class 14 02-18-2007 07:43 PM
valve stem seals replacememt ??? Guest (MBNZ) W201 190 Class 4 08-03-2005 03:10 PM
Valve Stem Seal Replacement donsig G-Class 2 07-10-2004 11:58 AM
Valve Stem Covers Mike M R170 SLK Class 6 03-11-2002 02:46 PM
valve stem seals replacement ???? Guest (MBNZ) W124 E,CE,D,TD Class 3 03-02-2002 09:32 PM
