» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Old 09-20-2009, 11:37 AM   #11 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
One quart is not sufficient.
Old 09-20-2009, 11:56 AM   #12 (permalink)
Date registered: Jul 2009
Vehicle: Black on Black 1997 E420
Another 1/2qt will meet the 1.5qt specifications then? I asked because the DIY only had one bottle of fluid.
amani356 is offline   Reply With Quote
Old 09-20-2009, 12:11 PM   #13 (permalink)
Date registered: Sep 2004
Vehicle: 1998 E300 TurboDiesel, 1988 300E 5-Speed, 1983 240D 4-Speed
Originally Posted by amani356 View Post
The Mercedes manual lists 1.4qts of differential fluid required. The DIY used 1qt of Redline fluid. Is this ok? Or purchase 2 bottles and use 1.5 bottles to meet specs?
the user manual for my vehicle, 1998 E300D TurboDiesel, also covers some of the other W210 vehicles of the day. There are different fill volumes for different engine options. The Diesel in my manual calls for 1.1 US quarts. Jim
JimSmith is offline   Reply With Quote
Old 09-20-2009, 12:49 PM   #14 (permalink)
loubapache's Avatar
Date registered: Feb 2007
Vehicle: 03 E320 4M Wagon & 97 E320
You definitely need more than one quart. How much exactly you need (more than 1 quart) is really not that important because you stop adding fluid when it overflows out of the fill hole.
As for capacity, different models use different differentials so the capacity could be as low as 1.1 liters (almost 1.2 quarts), 1.3 liters to as high as 1.6 liters.
Your 1997 E420 uses 1.3 liters (about 1.4 quarts).
loubapache is online now   Reply With Quote
Old 09-20-2009, 02:59 PM   #15 (permalink)
That's 1.1 liters, not quarts.
Old 10-05-2009, 10:45 PM   #16 (permalink)
Date registered: Apr 2008
Vehicle: C 240
owner manual for my 03 c 240 says to use 85w90.Is it OK to usr syntetic 75w90 for this car???
interceptor is offline   Reply With Quote
Old 10-05-2009, 11:43 PM   #17 (permalink)
Date registered: Jun 2004
Vehicle: 1995 S500, 2001 E55
anyone have the fluid capacity for the W210 E55 AMG diff?
Lawrence1 is offline   Reply With Quote
Old 10-08-2009, 10:02 AM   #18 (permalink)
I just did my differential fluid a couple of days ago. What are the mileage intervals?
Transmission fluid change tip ohlord W210 E-Class 53 11-19-2009 07:40 AM
type of differential fluid to use lushansilva W126 S,SE,SEC,SEL,SD,SDL Class 1 10-20-2006 08:41 AM
Differential Fluid Change cerritos W210 E-Class 1 09-18-2006 06:13 AM
Front Differential Fluid.. DerekJL W124 E,CE,D,TD Class 1 11-13-2005 10:17 AM
Transmission and Differential Fluid ch47pilot R170 SLK Class 5 06-07-2005 10:40 AM
