Boot / Trunk release switch not working. - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 11-07-2007, 06:52 AM Thread Starter
patrickdfisher's Avatar
Date registered: Oct 2007
Anybody out there that can help?
My remote key and the pressing of trunk lock both work fine.
The release switch light is on when trunk is open, but switch does not work.
My guess possibly its the switch, so i went out and bought one from MB.
Only problem is need knowledge of how to remove the wood plating surrounding the gear shifter ( E230 1997 Auto )so i can replace switch.
I would appreciate any help on this one as I dont want to damage it.
patrickdfisher is offline
post #2 of 15 (permalink) Old 11-07-2007, 10:53 AM
ohlord's Avatar
Vehicle: 1994 E320 Wagon,1999 E320 Wagon,2000 E 320 Wagon, MGB Track/Rally, ,1988 300E ,more....
Quoted: 5 Post(s)
A little
different on the 98-02 but should help
Step 1
work slow,don't force.
ohlord is offline
post #3 of 15 (permalink) Old 11-13-2007, 08:04 AM Thread Starter
Thanks!
I'll give it a shot.
post #4 of 15 (permalink) Old 05-09-2008, 02:37 PM
fju2112's Avatar
Date registered: Nov 2005
Vehicle: 2014 E350 4Matic sedan, 50K miles (purchased Jan 2017)
Quoted: 28 Post(s)
patrick, how did this work out for you? do you have the switch part number, can it be ordered from another place online, and how much was it?
same issue for me now!
Sold but not forgotten: 2002 E320 4matic sedan, black on beige ("sport" package - bird's eye maple trim, 17" sport rims), 108K miles upon sale.
RIP: 2000 E430 4Matic fully loaded - totaled 12/9/2006
fju2112 is offline
post #5 of 15 (permalink) Old 09-13-2011, 09:20 AM
Date registered: May 2011
Vehicle: 2002 E320
trunck release stopped working, keyfob works w/delay
I noticed when switch inside worked and w/keyfob, there started to be a delay of 3-7 seconds before the truck would open or even unlock. When I unlock car, I wiat a few seconds, then I hear a "click" from the back, then I am able to manually open trunk. If car has been unlocked for a while, no delay with manual operation or keyfob.
Now interior button has stopped working altogther, delay contunes when you try to use keyfob or open manually.
Finally, I pulled switch back (eventhough it stopped working), and it fell off. Looks like I need to get new switch (or glue back on?) and also figure out how to get trunk open from inside car and stop delay problem
greenE320 is offline
post #6 of 15 (permalink) Old 09-13-2011, 07:31 PM
Date registered: Jul 2011
Vehicle: 2000 E-320 4matic, Glacier White with Java interior 238K
The click is OK
When you're hearing the clunk in the back but the lid does not open, it's just the gasket sticking a little. If you haven't opened the trunk in a few days, this will happen.
For a pictorial on how to get to the switch, look at the youtube videos in the sticky sections -- there's a series showing disassembly of the center console. Just wha tyou need
jlgassler is offline
post #7 of 15 (permalink) Old 10-19-2011, 05:35 PM
Date registered: Oct 2011
Vehicle: 2002 E320
Interior trunk switch
As stated above, the trunk switch lights when the trunk is open, and the key remote opens the trunk, however, the interior switch does not open the trunk. Were you able to address this issue by replacing the switch? Would appreciate a response.
Thanks.
bigbucky5382 is offline
post #8 of 15 (permalink) Old 10-21-2011, 05:11 AM
~BANNED~
Date registered: Oct 2010
Vehicle: 1999 E300 TD
It may not be the switch. Look to the central locking section within the owners manual. It may be the way the trunk was locked via the key!! It does get confusing!
Plutoe is offline
post #9 of 15 (permalink) Old 11-03-2011, 12:23 PM
Vehicle: 2002 E320
Switch
Had a MB Tech do some diagnostics. The switch is defective. To replace the component is around $400. Can't justify that expense as the keyfob operates the trunk.
post #10 of 15 (permalink) Old 11-03-2011, 02:19 PM
Onyxblue97's Avatar
Date registered: Jan 2008
Vehicle: 97' E 320 //////02' C240
I agree with Plutoe ...just a few days ago I couldn't open my trunk
not with the fob nor with the key nor by pressing the button on the console.
Turns out My brother used the car used the key to open the trunki and unknowingly pulled out the key in valet mode position, therefore the trunk was totally disabled.
I grabbed the manual put the key in neutral position and right away it worked.
Just worth looking into. There are 4 functions depending on what position you pull the key out. lock onlock neutral and valet . Valet disables the trunk.
Onyxblue97 is offline
    w220 trunk release switch HOLIDAY W220 S-Class 3 04-26-2007 06:20 PM
    Remote IR Boot release problem plus Alarm manual coba R129 SL-Class 0 02-03-2007 03:02 PM
    Where is the trunk release handle (I know there is no gas door release) on 300SL bespokeonly R129 SL-Class 4 10-27-2005 09:05 PM
    trunk release bigbod500 General Mercedes-Benz 2 04-02-2004 12:48 PM
    Trunk release Guest (MBNZ) W201 190-Class 1 03-15-2002 07:25 AM
