» Featured Product
» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Old 11-05-2007, 08:24 PM   #1 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Lightbulb (Relatively) Common Issues for the W210
Hey, folks.
A frequently-asked question is (in essence) "hey, I just found a 210, should I buy it?" Quite often these questions come from those who are not familiar with MB and indeed, this might be their first MB. So I thought it might be useful to put together a laundry list of issues that are relatively common -- or at least things that should be carefully examined, preferably by someone who knows what they are doing.
I'm sure I've missed something, so feel free to add to the list, but remember the idea is to include things that several folks have seen, not just one or two.
If this works well we'll add it to the "tips and tricks" sticky.
AT gasket, mileage w/o changing filter/fluid
Catalytic Converters (noisy)
Console Pixels
Corrosion in rear seat pan (battery)
Differential Oil Leak
Groaning/Moaning Steering
Harmonic Balancer (recall)
Motor Mounts
Rear Bulb sockets
Rear Main Seal (V8)
Rear Window Regulators
Rust at exhaust hangers
Rust - Body
Seat Heater elements
Sensor, CPS
Sensor, MAF
Sensor, O2
Serpentine Belt Tensioner
Spring Perches (non 4-Matic sedans)
Sunroof
And of course it's important to have maintenance records reflecting regular fluid changes with proper fluids
If we ever forget that we are one nation under God, then we will be a nation gone under.
Ronald Reagan
In memory of our friend Ussun:
Old 11-05-2007, 08:30 PM   #2 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
Difference in temperature between the center vents with the AC running
Faulty volume control on the radio head unit
Dash cracks
Old 11-05-2007, 09:32 PM   #3 (permalink)
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
...more with part numbers....
Steering Rack - TSB
Brake Lamp Switch - very common (Part # 001-545-6409)
Auxilary Fan Module - (Part # 025-545-32-32 (For E55)
02 Sensor - (Error Code - P0141 = REAR 02 Sensor Part #: 000-540-81-17)
PRESERVE DOOR FRAME = MB OPEN SERVICE CAMPAIGN 200503005 for W203 / W210 Models (RECALL)
Seat Belt - Squick
If we can put the part numbers as well that would be great.
-JOE55
JOE55 is offline   Reply With Quote
Old 11-05-2007, 09:34 PM   #4 (permalink)
gregs210's Avatar
Steering Rack - TSB
Seat Belt - Squick
-JOE55
Well, actually, I was thinking of more of a checklist for inspecting, not general repairs/fixes...
Old 11-05-2007, 09:36 PM   #5 (permalink)
JOE55's Avatar
Vehicle: E55 ///AMG
I see, then ignore the part numbers then..
Old 11-05-2007, 09:38 PM   #6 (permalink)
JOE55's Avatar
Vehicle: E55 ///AMG
...plus you're going to sort-it-out later for the list right greg =)
Old 11-05-2007, 09:45 PM   #7 (permalink)
Date registered: Nov 2006
Vehicle: Oo == oO 98 E320
I'd add the steering column sleeve that rotates with the turn signal & cruise control stalks.
'87 300E: sold after 11years @ 230k & still on the road somewhere in rural Tennessee.
'94 C220 with 93k totalled 10/06 by hit & run broadsiding monster truck: not a scratch or bruise for me
johnamoss is offline   Reply With Quote
Old 11-05-2007, 09:48 PM   #8 (permalink)
ohlord's Avatar
Vehicle: 1999 E320 Wagon,2000 E 320 Wagon, MGB Track/Rally, 94 Subaru Wagon ,1988 300E ,more....
Inspect
Inspect BEFORE buying...........
Priceless
ohlord
"GOT CODES?"
Old 11-05-2007, 09:54 PM   #9 (permalink)
JOE55's Avatar
Vehicle: E55 ///AMG
^^Good Tip!
Old 11-05-2007, 10:14 PM   #10 (permalink)
Kajtek1's Avatar
Vehicle: E300TD/ML320/300DT
Mine pre-2000 W210 never had most of that stuff installed. Maybe splitting it on different years would make more sense. Why should I worry about pixels on car, that doesn't have the display?
Some might add muffler shine
Kajtek1 is offline   Reply With Quote
DIYs, Documents, Manuals, and FAQ links. Covers roof rattles, and other common issues cyberdrakon R171 SLK Class 7 04-22-2010 09:05 AM
W210 IR remote issues PPrash W210 E-Class 23 03-07-2009 09:12 PM
Some issues on a W210 E 320 CDI T, heater and diesel smell matzhinrichs General Mercedes-Benz 4 01-13-2009 10:01 AM
Braking/suspension issues? Electical issues in my 2001 C-240 wilhasl W203 C-Class 4 09-15-2005 05:11 PM
Reliability issues: W210 2001-03 wagon ? rl1856 W210 E-Class 7 07-18-2005 11:17 AM
