Old 07-14-2008, 07:00 PM   #31 (permalink)
ohlord's Avatar
update
722.4 you don't use mb spec it will kill it.Use dex3 atf3 or backwards compatible atf4 use mb spec 722.6 fluid in the 722.6 never in the .4
ohlord
Old 08-09-2008, 11:02 AM   #32 (permalink)
Date registered: Aug 2008
hello..
i need you help
i've mercedes w210 e230 year 98 automatic
When I drive the car, the transmission can shift but cannot to move when possiton on R, D, 2 , 3 or 4.. When I stop the engine wait 5 minute until cold and restart it, the transmission works normal again. The transmission problem comes and goes for several times. The transmission always go back to normal mode each time after the engine restart, butmust to wait 5minute or more..
after i read some opinion in this forum, i need your help..
my technical support says must changing torque converter automatic transmission.. that's expensive..
that's i want to ask you is
in your opinion i must change torque converter with new one or i can flush and refill ATF? and i must use oem mb atf ?
please i really need you help..
can contact me harrier_car@hotmail.com
thanks
aquafil88 is offline   Reply With Quote
Transmission Fluid Change, how much fluid? slk230red R170 SLK Class 5 03-07-2007 10:06 PM
How often to change transmission fluid-filter and diff fluid? Ramesh W126 S,SE,SEC,SEL,SD,SDL Class 14 08-17-2006 05:31 PM
To change or Not to change? -- That is the ML320 transmission fluid question!! ebrington W163 M-Class 6 07-20-2006 03:59 PM
Transmission fluid change penbed51 R170 SLK Class 5 06-13-2006 05:47 PM
Transmission fluid change - what fluid ???? Anjey W126 S,SE,SEC,SEL,SD,SDL Class 9 05-10-2005 01:18 PM
