Rough Idle No Codes Did not want to Hijack the other thread - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 10-17-2007, 09:33 AM Thread Starter
TNTRower's Avatar
Date registered: Sep 2007
Vehicle: '98 E320 Wagon (non 4matic)
Send a message via AIM to TNTRower
Hi guys!
I posted in the other thread and quickly realised that I was almost hijacking it with my similar symptoms.
Here is what the generic info is:
1998 E320 Wagon
123k miles
The harmonic Balancer had been replaced 15 months ago. The mileage was not indicated on the invoice.
When the car is stopped in Drive, there is a fairly noticeable vibration. When I shift it to Neutral while stopped, the vibration and noise disappear completely. Also note that the RPM will rise to about 750 from 500. When the engine is in Reverse there is very little vibration but still some. In Park, there is nothing.
When I drive there is no vibration but when I give it some gas it has the same noise as at idle but no vibration.
I was thinking that it may be mounts, but then wouldn't the vibration and noise be there all the time? I need to get the normal Tranny service done on it as it is. I am thinking that this will help. I will ask the Mech to inspect the engine mounts while he is doing it.
Any other thoughts or suggestions?
Thanks!
TNTRower is offline
post #2 of 9 (permalink) Old 10-17-2007, 09:58 AM
ohlord's Avatar
Vehicle: 1994 E320 Wagon,1999 E320 Wagon,2000 E 320 Wagon, MGB Track/Rally, ,1988 300E ,more....
Quoted: 5 Post(s)
Check
for pending misfire codes with your obd2 scanner,harbor freight tools in ga.,I know because i helped out a forum member that was stuck down there.
If no stored codes(pending).Then the symptoms most closely match the mounts,and very typical of a benz with your age and miles.
Stand to the side(be safe)and have someone power brake the car.Not to the stall point of the converter,just to about 1200 rpm,just have them repeat from idle to 1200 a few times so it rocks the engine,observe it.A major movement in the engine side to side is shot mounts.You can also get it up on some ramps to look for fluid leaking or obvious collapse.
Handy with tools?Laborious job, but easy diy .Same with the fluid change and on a 98 you can drain the torque converter so you get a complete fluid change over.
use only mb trans fluid,takes a bunch.
MercedesShop FastLane
trans fluid
Auto Parts at AutohausAZ - OEM Auto Parts - Discount Replacement Parts, Resources and Car Care Tips mounts
both have the special dip stick and filter so compare prices.
ohlord
ohlord is offline
post #3 of 9 (permalink) Old 10-17-2007, 12:10 PM
Mark Cummins's Avatar
Vehicle: W211/W210 Estate /W209/W208
Quoted: 4 Post(s)
The Easy items are the Motor mounts ..as they leak...the MAS will throw codes....and a Check Engine light.
I have seen a bad plug wire connector that WILL cause a Misfire and NO Codes
Found it with the SDS aka star in Values...One can watch the fire times of each cylinder
and since the 112/113 has twin plug ignition its not easy to find it without the SDS
Mark Cummins is offline
post #4 of 9 (permalink) Old 10-17-2007, 01:28 PM
ohlord's Avatar
Quoted: 5 Post(s)
Or
without going to the dealer for the use of the SDS any good real time scope/obd2 scanner like most indie shops have or if you are a die hard diy'r
AutoTap - OBDII Diagnostic Scanner for the lap top based real time unit.Under 200 bucks.
ohlord
Most likely the mounts,if he will go examine them first!!!
ohlord is offline
post #5 of 9 (permalink) Old 10-17-2007, 02:32 PM Thread Starter
TNTRower's Avatar
You ain't going to believe this...
Well I just got back from the Mechanic. He changed the ATF and Voila! The vibration is gone. He brought me out and showed me the engine mounts. He said that there is some evidence of wear but that they definitely do not need to be replaced at this time. However, he did show me where my steering rack is leaking!
So now I have to find about $1k to get that done in the not too distant future. He was kind enough to inform me that it was not a big leak and as long as I keep the correct Hydraulic fluid in the tank it won't really be a bother. He was kind enough to sell me a liter for $10.
Who's John Galt.
"Timeo Danaos et dona ferentes" - Virgil, The Aeneid, Book 2
If the Arabs put down their weapons today, there would be no more violence. If the Jews put down their weapons today, there would be no more Israel. --Benjamin Netayahu
TNTRower is offline
post #6 of 9 (permalink) Old 10-17-2007, 04:04 PM
Quoted: 4 Post(s)
[QUOTE=TNTRower;2586388]Well I just got back from the Mechanic. He changed the ATF and Voila! The vibration is gone.
So You are saying that your mechanic changed the transmission fluid and the Vibration is Gone?
Wow thats a first....Good One
post #7 of 9 (permalink) Old 10-17-2007, 05:34 PM
ohlord's Avatar
Quoted: 5 Post(s)
It will come back
most likely the lift took the weight off the suspension and when it settles back down the rocking will return.If not and a vibration was coming from the trans and a fluid change helped it,the transmission will be needing r/r in the future.
ohlord is offline
post #8 of 9 (permalink) Old 10-17-2007, 06:53 PM Thread Starter
TNTRower's Avatar
Oh great! Now I am jinxed!
Who's John Galt.
TNTRower is offline
post #9 of 9 (permalink) Old 10-17-2007, 06:55 PM Thread Starter
TNTRower's Avatar
[QUOTE=Mark Cummins;2586507]
I have had similar experiences with another vehicle. The previous experience was that when the the Tranny reached about 2200 rpm it would vibrate as it shifted. The darn thing was like driving over a shoulder rumble strip! Changed the ATF and it went away. Weird.
Who's John Galt.
TNTRower is offline
    Rough idle, no codes LorenzoBenzo W210 E-Class 28 10-19-2007 12:16 PM
    rough idle and codes renelsisc W140 S-Class 5 09-21-2007 11:04 PM
    S420 rough idle and codes hermanpat W140 S-Class 24 09-07-2007 07:28 PM
    ROUGH IDLE, IDLE CONTROL UNIT LOCATION, TIMING & RPM verdejor General Mercedes-Benz 5 01-22-2006 09:41 PM
    Bot's new thread (so as not to hijack the other one) djugurba Off-Topic 59 10-24-2004 01:41 PM
