Old 10-09-2007, 09:37 PM   #1 (permalink)
paulunm's Avatar
Date registered: Nov 2002
Vehicle: 2000 E55 AMG
Bilstein -> Koni Install Help '00 E55
I am in the process of installing Koni adjustables in place of my Bilstein HDs- need some help-
The Bilsteins have built in bump stops, but the Konis do not- and they were not included, I wasn't able to figure out how to take the bump stop off of the Bilstein (I believe it is on the shaft), any suggestions???
Thanks!!!!
paulunm is online now   Reply With Quote
Bilstein -> Koni Install Help '00 E55 paulunm W210 E50 AMG, E55 AMG 7 11-01-2007 04:57 PM
Bilstein vs Koni Darkmann W163 M-Class 7 10-09-2006 05:59 AM
What do you use? H&R or Eibach, Bilstein or Koni cdeeznuts W126 S,SE,SEC,SEL,SD,SDL Class 7 12-17-2003 03:40 PM
shocks - Koni vs. Bilstein ashmead W126 S,SE,SEC,SEL,SD,SDL Class 2 11-15-2002 06:54 PM
h&r or eibach? bilstein or koni?....(more) lower is better W208 CLK Class 6 09-20-2001 02:25 PM
