Old 10-09-2007, 12:45 PM   #1 (permalink)
Date registered: Oct 2007
Window relay location on 97 E420
Hi,
I am new to this forum as well as new owner of used 1997 E420. I got this car with front window’s not working. I started process of elimination and discovered that the fuse was blown under the rear seat and got my driver window to work by replacing blown fuse. I checked the fuse box on the right side of the cockpit and also one in the engine compartment and they are all good but I still can’t get the passenger window to work or the function to roll down all the windows up or down using the remote. My one touch is not working on the driver’s side as well and I did try to reprogram it. I can roll the passenger window up and down giving it the power inside the door panel which tells me that it is not my motor or window regulator. Is there a relay or some kind of module that I don’t know about that controls the windows? Any help will be greatly appreciated! Forgot to mention that the window switch is brand new as well and tested working.
igor78 is offline   Reply With Quote
Old 10-09-2007, 02:03 PM   #2 (permalink)
ohlord's Avatar
might help
to check
72 Doors
control module
ohlord
Old 10-10-2007, 01:36 PM   #3 (permalink)
Is there anything specific that I should look for since it seems like everything is connected right?
Old 10-30-2007, 12:24 PM   #4 (permalink)
Ok. I checked the control module and I can hear it click everytime you press the window switch. Is there anything else between control module and door that I need to check (relay,etc..)?
Old 01-12-2008, 01:53 PM   #5 (permalink)
Date registered: Jun 2007
Where is the door control module located, my power windows have stopped working.
wheeljo2 is offline   Reply With Quote
relay location MB300EUK W124 E,CE,D,TD Class 2 08-12-2007 06:12 AM
Relay Location jimmypop W126 S,SE,SEC,SEL,SD,SDL Class 1 05-20-2007 07:00 PM
GP Relay location help americanflyer302 Vintage Mercedes-Benz 1 03-24-2007 11:20 AM
relay location please sualk54 R129 SL Class 0 05-19-2006 05:18 PM
Relay Location? black560sel W126 S,SE,SEC,SEL,SD,SDL Class 0 04-29-2005 10:00 PM
