Old 10-08-2007, 04:10 PM   #1 (permalink)
Date registered: Sep 2006
Vehicle: 1999 e320 4matic
removing front springs
Hi All
Is there a way to remove the front springs to install new struts without a special tool? I have a 4matic
Thanks!
eastsidejp is offline   Reply With Quote
Old 10-08-2007, 04:51 PM   #2 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Originally Posted by eastsidejp View Post
Hi All
Thanks!
Hey, eastsidejp.
No way I know of. I tried three different kinds of "more conventional" spring compressors, the only one I know that works is the one in the DIY.
Take care and enjoy the ride,
Greg
Meister Eckhart
Old 10-08-2007, 06:18 PM   #3 (permalink)
ohlord's Avatar
the springs
Front and rear shock R/R,diy in the diy section by raymond,with the 4 matic and the different (stronger mount)spring compressor is avail at most good u rent shops.
ohlord
Removing springs w/o a compressor jtbeche W208 CLK Class 0 06-20-2007 03:28 PM
Help! Removing Rear Springs? W Cole W211 E-Class 1 01-15-2007 08:05 PM
Removing coil springs Bazzle R170 SLK Class 10 01-09-2007 06:41 PM
Removing front tires? SWORDFISH R170 SLK Class 14 12-01-2003 12:46 PM
Removing front springs. KliftonJK W123 E,CE,D,CD,TD,TE Class 5 06-20-2003 07:52 PM
