Old 10-03-2007, 08:56 PM   #1 (permalink)
Date registered: Jul 2007
Vehicle: 1996 Mercedes E320
Send a message via AIM to bk12321
stuck in park....
I went to start my car tonight to go to the store. Everything started up 100% fine. I went to change gears, and it will NOT move. The car ran fine the last time I drove it, and it has never done this before. I tried everything from pumping the brakes to holding the breaks to pushing on the back on the car while my friend tried switching the gears. Nothing.
I dont know whats wrong at all, does anyone have any idea????? It will NOT change from park whatsoever. I tried restarting the car about 6 times.
bk12321 is offline   Reply With Quote
Old 10-04-2007, 12:18 AM   #2 (permalink)
Date registered: Dec 2006
sounds to me like a bad brake swithc ...its located on top of the brake pedal..
try this
turn the car
step on brake pedal
look if you brake lights are working when you press the pedal
if not you have a bad sensor..
(note thise worked on my other cars..dont know about MB)
aguita is offline   Reply With Quote
Old 10-04-2007, 02:23 PM   #3 (permalink)
brake lights work just fine
i dunno i just went out to try to get it moving again and it just wont fucking move
guess im gonna get it towed
Old 10-09-2007, 09:09 AM   #4 (permalink)
the tow trucks on the way... something about a new brake switch.
if anyonee has this problem in a 99+ mercedez, you have a manual shift release located under D on your shifter, it should be like a little U shaped spot or something, but you stick a screwdriver or something in therre WITH YOUR CAR RUNNING and your foot on the brake, and you shoul dbe able to get it out of gear. Sadly they didnt have this on the 96 mercedez lol
Old 10-09-2007, 11:39 AM   #5 (permalink)
Cocca's Avatar
Date registered: Nov 2005
Vehicle: 2002 E430 4-matic
you can jam a pen in the hole to the left of the gear selector. see your owner's manual for the exact location. that action will allow you to bypass the faulty seitch.
2002 E430 4-matic
Cocca is offline   Reply With Quote
Old 10-12-2007, 08:59 AM   #6 (permalink)
that only applies to the 99 and up mercedes
mine has no emergency bypass
Old 10-12-2007, 10:13 AM   #7 (permalink)
Date registered: Aug 2007
Vehicle: 99 E55 AMG, 2002 E430, 2002 Dodge Grand Caravan ES
Hi....
2 things.....
1. you're in the wrong forum
2. you're cussing in the wrong forum
francisira is offline   Reply With Quote
Old 10-12-2007, 11:35 AM   #8 (permalink)
xlimodriver's Avatar
Date registered: Sep 2006
Vehicle: 96 E320, 07 Dodge Caliber SXT Sport
Originally Posted by francisira View Post
Hi....
2 things.....
1 thing.......
#1. I think, you think you're on your Dodge Soccer Mom Forum.
xlimodriver is offline   Reply With Quote
Old 10-12-2007, 12:12 PM   #9 (permalink)
Ryanoscerous's Avatar
Vehicle: 2001 E430 4matic
Hi....
2 things.....
This the right forum for all w210 issues.
Everything should be made as simple as possible, but not one bit simpler.
Albert Einstein
Ryanoscerous is offline   Reply With Quote
Old 10-12-2007, 01:19 PM   #10 (permalink)
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
Forgot to put a note on this one it was originally posted at AMG Section and moved it to this W210 Section, sorry for the confusion.
-JOE55
JOE55 is offline   Reply With Quote
stuck in park austinreza W208 CLK Class 10 06-16-2008 05:27 PM
Key Stuck In Ignition - Gear Stuck In Park hank4422 W210 E-Class 4 10-03-2007 08:54 PM
Help--stuck in park bobbypoz W208 CLK Class 0 08-13-2007 10:59 PM
Stuck in Park STL-Benz W163 M-Class 2 08-15-2006 07:45 PM
Stuck in Park!!!! ByByeAmericanPie W163 M-Class 10 12-06-2005 02:15 PM
