Old 10-03-2007, 08:54 AM   #1 (permalink)
Zackb951's Avatar
Date registered: Dec 2006
Vehicle: 1997 E300 Diesel
Send a message via AIM to Zackb951
Suspension noise, narrowing down possibilities
I have been trying to isolate the cause of my suspension noise. It is notable going over bumps and rough roads that it does not feel/sound like a Mercedes should. The sound is rough as if bad shocks. The car has 158K miles on it.
I have replaced the following:
-Sway bar endlinks ~10K miles ago (reduced a lot of noise at the time!)
-Front lower ball joints- ~1-2K miles ago
-All 4 shocks (Sachs/Oem) last night!
Tire pressure is 27psi all around on OEM rims and grand touring tires. I am running out of options. I keep hearing LCA bushings give a shimmy ~55, I don't have any noticeable shimmy. Does anyone else have any ideas or definitive ways to check?
New LCA's with bushings run $200/each thats an expensive gamble if it is not the cause...
Zack
1997 E300 Diesel
Depo Headlights with RS6 Bi-Xenons
Zackb951 is offline   Reply With Quote
Old 10-03-2007, 09:34 AM   #2 (permalink)
Date registered: Jan 2007
Vehicle: 2005 S500 4matic Sport Designo
id have to guess the bushings.
Have you taken a look at them to see if they are leaking/cracked?
OliverK is offline   Reply With Quote
Old 10-03-2007, 10:05 AM   #3 (permalink)
Date registered: Aug 2007
Vehicle: 1998 E320 4matic wagon
I replaced bushings trying to get rid of the noise I got over bumps, but it finally went away after I replaced the belt tensioner. You would think it would have made a bad groaning sound being that far gone, but it was pretty quite while the engine was at idle. So I'd verify that everything the belt turns is OK, good luck, I know how annoying those suspension noises are!
korbenz is offline   Reply With Quote
Old 10-03-2007, 02:56 PM   #4 (permalink)
l-pagan's Avatar
Date registered: Feb 2006
Vehicle: 99 E430 sport
Sway bar bushings
l-pagan is offline   Reply With Quote
Old 10-03-2007, 03:36 PM   #5 (permalink)
belegedhel's Avatar
Date registered: Apr 2006
Vehicle: 1998 E320
My E320 has 120k on it and recently started making a rubber-scrunching sound when going over big bumps (like a speed bump) at low speeds. I replaced the sway bar bushings, and all was quiet for about 2-3 weeks, and then there was a new noise. I was convinced it was coming from the drivers side upper control arm bushing. Paid the dealership $350 to swap it out, and so far things are reasonably quiet again. There was nothing visible to indicate that the control arm bushing was bad, that is just where the sound seemed to be coming from. Sway bar bushings were definitely worn. Dealership lacked any talent for locating the noise, they just wanted to start with the cheapest part and replace things until they found out what was really at fault.
belegedhel is offline   Reply With Quote
Old 10-03-2007, 06:22 PM   #6 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Originally Posted by l-pagan View Post
Sway bar bushings
He already changed them...it would be odd if they're already shot after 10,000 miles.
Zack, you can buy and install loaded upper a-arms (ball joint and bushings installed), you'll have to get it realigned but they can go bad too.
Personally I think I'd take it to a couple of indie shops and tell them you can't find the noise, you need a new mechanic, here is what has been changed. Let them diagnose it, lots will do a quick check for free. But I'd have to think that the frustration level has to be pretty high at this point, in your shoes I might be willing to pay for an indie diagnosis.
Just a thought, but any vibration at idle? If so and your motor mounts were gone that could be felt and heard over harsher bumps.
Take care and enjoy the ride,
Greg
Meister Eckhart
Old 10-04-2007, 08:48 AM   #7 (permalink)
Date registered: Jan 2004
Vehicle: 1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL
He says he replaced the sway bar links - no mention of the bushings though.
Len
sokoloff is offline   Reply With Quote
Old 10-04-2007, 10:01 PM   #8 (permalink)
ohlord's Avatar
your
tire pressure is to low,esp for a diesel.Find the value for compressed spring height,your coils may be shot.Over 100000 miles on a D car,inspect those motor mounts,could be collapsed or leaking.
ohlord
Old 10-05-2007, 07:44 AM   #9 (permalink)
Didn't notice he had a diesel. The mounts need to be done if they are original at that age/mileage. They are going to be collapsed some, maybe a lot. I doubt that there is any issue with your springs - they ought to last you the life of the car.
Len
Old 10-05-2007, 10:45 AM   #10 (permalink)
Zackb951's Avatar
ohlord
Fogot to mention Motor mounts were done 3 weeks ago
The tire pressure is the correct pressure for the diesel, any more would make it worse.
I HIGHLY doubt my springs would be worn, that just doesn't happen. spring bushings/rubber mounts perhaps, but still unlikely.
Zack
Suspension Noise Kenvid R129 SL Class 1 09-16-2006 12:45 AM
suspension noise youngMB W202 C-Class 3 10-29-2004 05:21 AM
noise from suspension? madmatt R171 SLK Class 0 10-20-2004 06:36 PM
Suspension noise nhajari W202 C-Class 3 02-28-2004 03:02 PM
Suspension possibilities: Guest (MBNZ) W210 E-Class 5 12-26-2001 09:46 AM
