Old 10-03-2007, 07:53 AM   #1 (permalink)
Date registered: Feb 2007
Vehicle: 1997 Mercedes E300D
Question 1997 E300D EGR Valve problem
Hi Guys, I have just cleaned out my air manifold along with cylinder head ports & could not believe the amount of sludge & carbon in the system, all created by the EGR valve, I guess. Is there a way I can put a blank in the EGR flange without setting off the check engine light??
Baggy is offline   Reply With Quote
Old 10-03-2007, 08:39 AM   #2 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
It's a combination of the EGR and the crankcase ventilation. Disabling either will probably help, both will help more. If you have no MAF sensor, I don't think you'll throw a code by putting a plate between the valve and the manifold. But you can't remove the valve.
Before you do so, consider how long it took to build up that crud, and decide if it's really necessary to do anything but clean it out every decade or so.
Old 10-03-2007, 12:45 PM   #3 (permalink)
ohlord's Avatar
You can
do a search of the speedo cable on a drill to clean out of the egr tube,also a ball bearing installed in the tube large enough to not fall into the egr will disable the function of the valve while leaving it in place.
removing egr tube from egr valve....benefit brandon671 W126 S,SE,SEC,SEL,SD,SDL Class 12 07-26-2007 11:02 PM
HELP: 95 E300D shut off valve diesel leak problem? stuttgart W124 E,CE,D,TD Class 2 04-26-2007 03:05 AM
EGR valve problem orlandotrader W163 M-Class 0 06-11-2006 08:47 PM
egr valve bouzouki W140 S-Class 4 01-22-2005 08:46 AM
In search of any 1997 E300D feedback smartlilbenzgirl W210 E-Class 1 05-05-2004 10:44 AM
