Old 10-01-2007, 07:40 AM   #1 (permalink)
Vehicle: W210 - E320 - 1997
Send a message via Yahoo to hhrahman77
ABS - ETS , Diangnosis report interpertation
I diagnosed my ABS/ETS system on carsoft and it gave me this message... I got several question after u read the report
Single diagnosis ABS / ASR - Status: ERROR
Module Info : ABS / ASR
Module :ASR
MB - Nr. :
015 545 76 32
Supplier :Bosch
Hardware-Version:10/93
Software-Version:51/93
Diagnosis recogn.:4/02
abs_feh.dxt3
12 ABS : Master cylinder switchover valve.
Check the internal resistance. With IGNITION=OFF : 7-8 Ohm.
Models : 140.04/05
12 ASR / ETS : Magnetic valve relay
Check the power supply from the magnetic valve relay.With IGNITION=ON : 11-14 V
Also check the resistance of the coils : 40-80 Ohm (IGNITION=OFF)
And the working contact : 11-14 V (IGNITION=ON)
- Single diagnosis completed
1. What is a Master Cylinder Switchover Valve?? Where is it?? How to fix it?
2. What is Magnetic Valve Relay??Where is it?? How to fix it?
3. Resistence of the Coils??? Does it mean Ignition Coils???
hhrahman77 is offline   Reply With Quote
I NEED HELP! My ABS and ETS lights came on. DETANE W210 E-Class 8 05-12-2006 02:46 AM
ETS and ABS stewedg R129 SL Class 2 11-13-2005 01:40 PM
ABS ETS Help AL-Sayegh W140 S-Class 6 08-26-2004 02:22 PM
ETS BAS ABS AL-Sayegh W163 M-Class 2 05-16-2004 11:56 PM
ABS AND ETS COME ON.......PLEASE HELP HERNANZA W210 E-Class 2 09-02-2003 06:53 PM
