Old 06-01-2008, 10:29 AM   #31 (permalink)
Date registered: Aug 2007
Vehicle: W210 1998 E430
Originally Posted by Kajtek1 View Post
WOW 135 Canadians???? That's a fortune in US$
I complained spending like $80 at autohouseaz for mine..
Only because the mounts for ML (same engine) cost about $26
About 7 years ago mounts for W123 were nine bucks.
Yeah, tell me about it. The US has a much larger market share and presence, so many things are still quite a bit cheaper in the US.
Benzboy210 is offline   Reply With Quote
Old 08-20-2008, 01:27 PM   #32 (permalink)
Date registered: Jul 2008
Vehicle: 2002 e320 wagon 4matic
I just checked autohausaz and see only one engine mount listed for the 2002 e320 wagon 4matic. I thought there are 2 and that they are different. I am confused. Thanks.
e320talk is offline   Reply With Quote
Old 08-20-2008, 01:36 PM   #33 (permalink)
Date registered: Mar 2006
Excellent instructions (engine mount). If only the W163 forum can get the same.
mlfun is offline   Reply With Quote
Old 11-04-2008, 11:57 PM   #34 (permalink)
roadster49's Avatar
Date registered: Nov 2007
Vehicle: 1997 Mercedes S500 Coupe
Any concern crushing the oil pan? Plan to do w140 and it would be nice to have similar detail
roadster49 is offline   Reply With Quote
Old 11-05-2008, 11:12 AM   #35 (permalink)
G-AMG's Avatar
Date registered: Oct 2005
Vehicle: '04 G55 '80 280GE '99 S420 '98 E320
UUuuuhhh, Roadster, was I not clear enough in the following Photo post?
http://www.benzworld.org/forums/w140...lacements.html
G-AMG is offline   Reply With Quote
Old 11-05-2008, 11:46 AM   #36 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Awesome. A post in the wrong forum for the car, b/c the specific DIY in the home forum for the car was missed. Sweet.
Meister Eckhart
HOW CAN DIY , MOTOR ,MOUNT,S mel dwyer W140 S-Class 6 11-02-2008 01:18 PM
Photo Diy- Steering Wheel Removal G-AMG W210 E-Class 13 07-17-2007 10:44 AM
Photo Diy- Extraction Oil Change G-AMG W140 S-Class 18 03-04-2007 01:52 AM
Photo Diy- Pitman Arm Adjustment G-AMG G-Class 0 11-20-2006 08:12 PM
Engine replacements ended? Dan350 R171 SLK Class 29 09-23-2005 12:05 PM
