» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Old 11-18-2007, 01:08 PM   #21 (permalink)
Date registered: Jun 2007
Replaced C220 mounts today without removing A/C compressor. After removing washer fluid reservoir and air filter housing I jacked the engine putting a twist/slant on the left side giving me the room to r/r the mount. Think this twist was same as using a tire iron to rotate engine. Car runs soooooo much better now.
b6542 is offline   Reply With Quote
Old 01-16-2008, 05:46 PM   #22 (permalink)
johnny's E320's Avatar
Date registered: Jan 2008
Vehicle: E320 (W210)
Exclamation
IMPORTANT TO ELIMINATE FRUSTRATION...ON SOME MODELS...
I have a 1998 E320 W210 with a belt tensioner that has both a 19mm outer bolt (in the center of pulley) and a T-50 Torx with center 'nipple' or 'peg' in the center of the torx. If you can't get your tools on them to get a grip, take a look underneath the tensioner housing and to the left (passenger side on US models) and you might notice (on some models) a large integrated hex head (I think its a 17mm). You can slide on a socket and use this to release the tension on the belt.
I grappled with the pulley bolt and torx and found them to be stripped enough to cause great angst! Then I found out about the hex head nut underneath.
Problem solved...and now I can continue with my mounts.
This thread is a lifesaver!! G-AMG, you rock!
Johnny
johnny's E320 is offline   Reply With Quote
Old 05-30-2008, 11:43 AM   #23 (permalink)
Date registered: Aug 2007
Vehicle: 2007 GL450, 1998 E430
SUCCESS!
Just did the mounts on my 1998 E430 - easy job! A BIG THANKS to G-AMG for the DIY and torque specs, much appreciated!
Some notes:
1) I disconnected the battery. Easy to do - there is a small plastic access panel in the rear passenger seat footwell area. An 11mm socket will undo the negative connection there. Remember to leave your driver's seat in the favorite position. Upon restarting the car and hooking the battery back up, I immediately saved the seat memory and you also have to re-sync the windows and sunroof (press up and hold at closed position for a few secs). Also got the BAS warning which went away after driving a bit and restarting.
2) There was NO NEED to disconnect the AC compressor with the M113 V8. At least not for my model year. As someone else with the V8 mentioned, there is plenty of room to slide the mounts out.
3) Only tools I needed were the standard sockets/ratchets, torque bar and a regular jack.
4) Tip about marking the old mounts with a Sharpie before removing to remember orientation is a good one! Make sure to line everything back up as per the little notch.
5) I did remove the fan shroud - you will probably need the clearance, so you may as well remove it. Very easy - two clips at the top, remove them and slide the shroud up.
All in all took me about 1.5 hrs. Could easily do it in 30-45 mins second time around. Slowest part is the upper bolts, not much room to ratchet.
Here are some pics - the driver's side mount was completely TOAST! Leaking oil and the rubber was shredded.
I honestly can't believe the difference now! I swear that the engine is off at idle, it is ridiculously smooth. I think that since they fail slowly, you don't really notice it until they get bad. If you have a shudder or vibration at idle, check your mounts. Easy and inexpensive DIY and the results are worth it.
Big difference in height!
Oil's not well here!
Benzboy210 is offline   Reply With Quote
Old 05-30-2008, 11:53 AM   #24 (permalink)
Mark Cummins's Avatar
Vehicle: W211/W210wagon/W209
Nice write up..This should be a sticky
Note
on the W210 Wagon/Estate the drivers side motor mount is a LOT harder as you have Two Metal lines going to the rear suspension that are in the way...As I have done a few..
Mark Cummins is offline   Reply With Quote
Old 05-30-2008, 03:00 PM   #25 (permalink)
Note
Mark, it is a sticky, that's how I found it!
It's under the DIY stickies that gregs210 posted, under 'Engine...'
Cheers.
Old 05-30-2008, 11:25 PM   #26 (permalink)
Kobus's Avatar
Date registered: Apr 2007
Vehicle: 2001 SLK 320(111K Miles), 2002 E320 Special Edition(122K Miles)
Am I just imagining it, or does the new mounting has a plastic/rubber body, while the old one was metal?
Only two thing are infinite, the universe and human stupidity, and I'm not so sure about the former.
Albert Einstein
Honest politicians are like UFOs. Most people believe that there must be some out there somewhere, but nobody has yet been able to prove their existence.
Kobus is offline   Reply With Quote
Old 05-30-2008, 11:31 PM   #27 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/ML320/Audi A4 quatro
the mount has a metal "cup" outside and metal "Shaft" inside what is all vulcanized with the rubber. Even when the rubber deteriorate the shaft is not leaving the cup, therefore judging the condition of the rubber is so difficult.
What you see on the picture is metal cup painted black, what matches the rubber color.
Looks like Benzboy got different mounts than original, so the shape is slightly different.
Kajtek1 is offline   Reply With Quote
Old 05-31-2008, 01:47 AM   #28 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
They are something other than OEM; you can tell by the bottom as well, smooth not ridged. It is weird that they vulcanized the whole outside, but maybe that will provide a bit more insulation and they will last longer.
The right (passenger) side on the E320 V6 can be done from the bottom with a flex-head ratchet coming in from the back to get the top bolt. Given the proximity to battery amperage at both the starter lug as well as the alternator lug, it's definitely indicated on that engine to disconnect the battery. The ten minutes to resych everything is cheap insurance. From my perspective with the driver's side it was harder to deal with the AC compressor than with the motor mount.
Take care and enjoy the ride,
Greg
If we ever forget that we are one nation under God, then we will be a nation gone under.
Ronald Reagan
Old 05-31-2008, 11:01 AM   #29 (permalink)
The mounts are made in Germany by Corteco, part of the Freudenberg group. The metal part in the middle is covered by the rubber, not painted. As gregs210 said, not sure why - perhaps more insulation as mentioned? They are stamped with the same part number as the mounts I took off my car. They weren't cheap, $135 each here in Canada.
Either way, I'm a happy camper!
Old 05-31-2008, 06:27 PM   #30 (permalink)
Kajtek1's Avatar
WOW 135 Canadians???? That's a fortune in US$
I complained spending like $80 at autohouseaz for mine..
Only because the mounts for ML (same engine) cost about $26
About 7 years ago mounts for W123 were nine bucks.
HOW CAN DIY , MOTOR ,MOUNT,S mel dwyer W140 S-Class 6 11-02-2008 01:18 PM
Photo Diy- Steering Wheel Removal G-AMG W210 E-Class 13 07-17-2007 10:44 AM
Photo Diy- Extraction Oil Change G-AMG W140 S-Class 18 03-04-2007 01:52 AM
Photo Diy- Pitman Arm Adjustment G-AMG G-Class 0 11-20-2006 08:12 PM
Engine replacements ended? Dan350 R171 SLK Class 29 09-23-2005 12:05 PM
