» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Old 09-14-2007, 07:54 PM   #1 (permalink)
reyna7's Avatar
Vehicle: 2000 E430 Sport
Thumbs up Spring Compressor in action...
After receiving a $900 shocks & springs install quote from the local stealership (8 hours) and similar from indie (who stated the rear would take four hours because the rear seat had to be removed to access the upper shock mount) I’ve decided to invest in a spring compressor and DIY.
While researching the job I came across this link that really helped me make up my mind to do it myself.
I know there is a ton of interest so perhaps it would make a good addition to our DIY section?
How to use a Klann KL-0025 spring compressor
reyna7 is offline   Reply With Quote
Old 09-14-2007, 07:59 PM   #2 (permalink)
raymond-'s Avatar
Date registered: Jan 2004
Vehicle: 99 E320 Depo/E55bix, clear fogs, E55 rims/tails/seats, Audio10, BilsteinSport, cut springs
it used to be in the DIY but appears to have disappeared with recent reorg. good
catch....let's get it back in there, along with specific 210 tips. p.s. in reality the 210
R&R of springs is a little more complicated (more like intermediate) than it appears
in the video.
raymond- is offline   Reply With Quote
Old 09-14-2007, 08:07 PM   #3 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Actually, I don't recall ever seeing it, but at any rate it is in there now.
Thanks, reyna7.
After watching that I now understand why that is a $700 tool. (sigh.)
Take care and enjoy the ride,
Greg
If we ever forget that we are one nation under God, then we will be a nation gone under.
Ronald Reagan
Old 09-14-2007, 08:09 PM   #4 (permalink)
reyna7's Avatar
in the video.
Thanks Raymond & definetely agree w/ you.
I'll take all the help I can get on this (especially considering the other option$).
Old 09-14-2007, 08:16 PM   #5 (permalink)
reyna7's Avatar
Thanks, reyna7.
Greg
That $700 price tag is a killer.
Searched Ebay and saw similar (looks exactly the same) for less than half that amount. Considering the dangers of smashing my face in I dunno if the savings are worth it. Others have used the Ebay ones with success so maybe I'm worrying too much?
Old 09-14-2007, 08:55 PM   #6 (permalink)
raymond-'s Avatar
the zdmak (seller) Klann clone has been used with good success by easily a dozen
folks on this board, MBworld, and Mercedesshop....myself included. I've done 5
spring swaps with mine....and all fingers intact. seriously, it works smoothly, no
binding, and appears to be very well finished and constructed.
Old 09-14-2007, 09:18 PM   #7 (permalink)
mbnz230's Avatar
Date registered: Jun 2004
Vehicle: 2000 e320 + 1996 s320 + 1998 c230
very good thread, this was what i wanted to know also. so this means, i can remove the factory springs and drop in some h&r's with this compression tool.
if i do drop in some lowering springs will it ruin the alignment and the camber at the same time.
mbnz230 is offline   Reply With Quote
Old 09-14-2007, 09:29 PM   #8 (permalink)
mbnz230's Avatar
will this spring compressor work in our w210?
Old 09-15-2007, 09:51 AM   #9 (permalink)
raymond-'s Avatar
anytime you monkey with the suspension, you must keep in mind that it *will* alter
the specifications. the question is "how much?" after alteration, just get it realigned,
which usually runs $100 or thereabouts, or drive for few hundred miles and gauge
via secondary measures such as tire wear. but the latter is a gamble and you may
still need it anyway.
yes it will....but not effectively. since nearly all the time spring R&R is done for
lowering purposes on the 210, you're proposing using this design for shorter
springs. if you look at the pic and pivot the hooks so that they are positioned
in extended fashion, you'll see that it used much more effectively for long traveled
springs.
so though it will be useful ....a little..... you'll not be able to utilize this design to
the degree needed....and which is possible with the pancake design. in fact,
even the pancake design may encounter full compression and still.....there isn't
enough space available between spring coils (the coils will touch) to compress
any further (to allow its removal). this is where the trick of dropping the lower
control arm....or releasing the sway bar linkage trick is needed.
do you have a spring compressor? NüR-SPEC W126 S,SE,SEC,SEL,SD,SDL Class 20 05-29-2007 07:16 AM
My new spring compressor is on the way. hotwheelbill W123 E,CE,D,CD,TD,TE Class 0 03-26-2007 12:58 PM
Linh, do you know how to change spring pads without a spring compressor? SteveL R170 SLK Class 7 04-05-2002 02:34 PM
PROCEDURE FOR SPRING INSTALLATION WITHOUT THE SPRING COMPRESSOR Linh R170 SLK Class 0 06-20-2001 10:34 AM
CHANGE SPRING WITHOUT USING SPRING COMPRESSOR..? YES, I DID MY YESTERDAY. Linh R170 SLK Class 3 05-07-2001 03:34 PM
