Old 09-20-2007, 08:30 AM   #11 (permalink)
Date registered: May 2005
Vehicle: '07 GL320CDI, '06 E320CDI
"Neglected" is an advertising word created by those selling a product, in this case oil.
Any real engineer will tell you power steering fluid is not particularly abused in its application.
Did you change the filter?
Kent Christensen
Albuquerque
Old 09-20-2007, 01:52 PM   #12 (permalink)
Paul Mellerowicz's Avatar
Date registered: Aug 2007
Vehicle: 1998 E-320
Location: West Bloomfield, Michigan (just north of Detroit)
Ikchris and all,
I assume that you are saying that there is a filter somewhere for the power steering unit.
Tell me about. Where is it to be found? Is it a metal screen, just to be cleaned or is it an element to be replaced?
If there is one there, I will certaintly address it along with changing out the power streering fluid.
I have a 1998 e-320 with 100,000 miles . This is the last of the fluids that I must service. I did all the other fluid changes (brakes, rear diff. trans, oil (on regular interval).
Thanks
Paul Mellerowicz is offline   Reply With Quote
Old 09-26-2007, 06:31 AM   #13 (permalink)
Date registered: Jan 2004
Vehicle: 1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL
No power steering filter in yours.
Len
sokoloff is offline   Reply With Quote
Old 09-26-2007, 07:51 AM   #14 (permalink)
Vehicle: 99 E55 AMG, 2002 E430, 2002 Dodge Grand Caravan ES
re power steering
i have a 99 e55, where is the reservoir?
francisira is offline   Reply With Quote
Transmission Fluid in the Power Steering Fluid reservoir ldshull Vintage Mercedes-Benz 4 06-12-2006 11:59 AM
Colour of power steering fluid after p/s fluid & filter change -- normal? Rollingstone W126 S,SE,SEC,SEL,SD,SDL Class 14 05-03-2006 09:12 AM
Hydraulic Fluid/Power steering Fluid panzerwagon_350slc General Mercedes-Benz 4 09-07-2005 11:06 AM
which one is the power steering fluid? cosworth2.3owner W201 190E, D-Class 4 06-01-2005 09:50 PM
Power steering fluid guldenj G-Class 2 07-16-2004 09:50 AM
