» Site Navigation
» Other Sites
Old 09-09-2007, 05:03 PM   #1 (permalink)
Date registered: Mar 2006
Engine starts intermittently. 1999 E320
My problem is that the I will try to start my car, and the starter turns, BUT the engine wont start. However, if I let it wait a few minutes, sometimes the engine will start!!??
I just called Mercedes Roadside Assistance for a battery replacement, but the gentlemen on the phone did say that this is not likely the battery. Most likely this is the crank sensor position sensor or fuel pump/ pump switch.
Anyone else have this problem?
Car is a 1999 E320 with 155,000 miles so I do expect to be replacing parts around now!
rolypoly is offline   Reply With Quote
Old 09-09-2007, 05:08 PM   #2 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
rolypoly, welcome to the forum
If you search you'll find several threads with your issue and the solution 99% of the time is to replace the crank position sensor. It's available online at lots of places in the $80 range.
If you look in the diy sticky you'll even find a pictorial on how to do it yourself.
Take care and enjoy the ride,
Greg
1995 E320 Valve Lifter Noise,Intermittently Mercaussie W124 E,CE,D,TD Class 7 08-23-2007 07:51 PM
engine misses intermittently 247hoopsfan W124 E,CE,D,TD Class 0 01-31-2006 10:56 AM
1999 ML 430 starts sporatically..................... ReBell W163 M-Class 4 09-20-2005 12:38 PM
Check engine light - 1999 E320 - gas cap? bossman280 General Mercedes-Benz 3 05-14-2005 01:02 AM
Check Engine Light 1999 E320. mr_anthony Original Vendors 1 12-15-2003 08:28 PM
