To start with, this was SUPPOSED to be a wheel bearing adjustment post. While rotating my tires, the front wheel bearings felt "loose" when I would check for play (grabbing tire, and vigorously shaking side to side on wheel----in relation to the axle).
When it came to an actual measurement, though, it was spot on.
Anyway, since I did the work, I thought I would at least post the diagnostic portion.
Thanks for another DIY; your facilities look excellent, we're all jealous.
I'm heading to the DIY sticky right now to add this, thanks again.
Take care and enjoy the ride,
Greg
