Old 08-30-2007, 07:16 PM   #1 (permalink)
srfox's Avatar
Date registered: May 2005
Vehicle: 02 G500
Cam or Crank Position Sensor???
My 98 E320 started stalling randomly while driving, and then not restarting for hours. Up until tonight it always happened somewhere convenient.
Coming from a BMW background, my first thought was to replace the CAM positioning sensor on the FRONT of the engine, which I did. Car ran fine for a couple of days, but stalled tonight big time in traffic and just arrived home on the back of a flatbed. I suspect it will start fine tomorrow but no way am i taking it anywhere.
So now do I replace the CRANK positioning sensor on the BACK of the engine?
BTW no codes, no CEL. Turns over awesome, won't fire.
Steve
98 E320
02 G500
00 M5
srfox is offline   Reply With Quote
Old 08-30-2007, 07:34 PM   #2 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/320cdi ML320/55
Does tachometer move when you crank?
It might be either CPS or fuel system. Did you test fuel pressure on the rail?
Kajtek1 is online now   Reply With Quote
Old 08-30-2007, 08:16 PM   #3 (permalink)
srfox's Avatar
Vehicle: 02 G500
I'll check the tach in the morning, but as I recall it did not move. Thanks!
Steve
Old 08-30-2007, 08:50 PM   #4 (permalink)
srfox's Avatar
Vehicle: 02 G500
Update: two hours after the tow truck left, the car started right up without me doing anything to it.
Are MBs secretly made in England by British Leyland?
Steve
Old 08-30-2007, 09:54 PM   #5 (permalink)
ohlord's Avatar
CPS
R/R seems to be in order,no codes it is failing.Multi meter could check it out but I don't have the resistance value,autohausaz.com,free shipping over $50.diy on this site,have a good flashlight it's dark down there,also put on gloves(latex)and watch out for the fender well heat shield(sharp)
ohlord
"GOT CODES?"
Old 08-31-2007, 05:12 AM   #6 (permalink)
Date registered: Feb 2007
Vehicle: 99 E430 Sport
I had that happen to me once, where it stalled on me, but was lucky enough that i was able to restart it right away. Best thing to do is to change the CPS. If it happens again i say change the fuel filter to see if it doesnt any improvement.
99 E430 Sport
Totalfixation is offline   Reply With Quote
Old 08-31-2007, 08:31 AM   #7 (permalink)
srfox's Avatar
Vehicle: 02 G500
Car running fine this morning, at least in the driveway. I pulled the CRANK position sensor and the business end of it is scored a little, like it was in contact with something rotating. seems odd. ordered one from AZ AH, $50.00 cheaper than local dealer.
Steve
98 E320
02 G500
Old 08-31-2007, 10:28 AM   #8 (permalink)
ohlord's Avatar
Dirt,debris,
Chip of metal,can all damage the cps.It is the nature of the beast in the environ it operates in.When you r/r make sure to treat the new one with care and also check the wires at the hook up.After install a dab of dielectric grease on the point where the wires plug into the sensor,will help displace moisture and heat,helping prolong the new cps.
ohlord
"GOT CODES?"
Old 08-31-2007, 10:58 AM   #9 (permalink)
srfox's Avatar
Vehicle: 02 G500
ohlord
"GOT CODES?"
Thanks, good idea on the dielectric.
Steve
Crank Position Sensor dannydang W220 S-Class 14 11-03-2008 07:51 AM
crank angle sensor or crank position sensor Gwagensofli G-Class 1 07-31-2007 04:37 PM
cam position sensor dougavery R129 SL Class 0 03-14-2007 08:12 AM
Crank position sensor, where is it? starscream W140 S-Class 3 10-03-2006 08:55 AM
