Old 08-29-2007, 04:09 PM   #1 (permalink)
moaad001's Avatar
Date registered: Aug 2006
Vehicle: E200 CDI from '00 facelift
Send a message via MSN to moaad001
Exclamation ESP-ABS-BAS Malfunction help please
Hi
I drive a E200 CDI from 2000. When driving my car (after 2 km) I get the ESP-ABS-BAS malfuntion in my clusterboard. This started about a week ago when I brought my car to a tire center for adjusting my steering wheel direction.
After this visit I always get these errors.
Somebody ... ?
Thanks...
moaad001 is offline   Reply With Quote
Old 08-29-2007, 05:06 PM   #2 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Originally Posted by moaad001
Hi
Somebody ... ?
Thanks...
Hi, Mo, and welcome to the forum.
There are a few things it might be, but personally I think I'd revisit the tire center. Since it didn't do it before, then started after you left, they obviously triggered something. If you start trying to figure it out you may make it worse, or they may then say "hey, it's your responsibility since you messed with it." If you just take it back then you can instead say "hey, it's your responsibility since you messed it up."
Take care and enjoy the ride,
Greg
Meister Eckhart
Old 08-30-2007, 04:53 AM   #3 (permalink)
A1EK's Avatar
Date registered: Sep 2005
Vehicle: W208 CLK230 Kompressor 2000 year, Brabus Monoblock VI, 15mm spacers, Eibach Pro Kit, Flat emblem
Try the brake switch, very common fault, and cheap and easily fixed. It could be that the two incidences are seperate and are not to blame.?
A1EK is offline   Reply With Quote
Old 08-31-2007, 04:00 PM   #4 (permalink)
l-pagan's Avatar
Date registered: Feb 2006
Vehicle: 99 E430 sport
Hi
Somebody ... ?
Thanks...
start car turn wheel all the way to the left and then all the way to the right to reset,
l-pagan is offline   Reply With Quote
Old 09-11-2007, 04:38 AM   #5 (permalink)
moaad001's Avatar
I've tried everything but the problem is not the brake switch. I did a test with pressing the brake pedal and releasing it after 2 min but the ESP-ABS-BAS malfunction doesn't appear. I think it is a problem with the steering sensors. Does somebody has experience with these sensors?
Thanks a lot for the help guys
Old 09-11-2007, 05:23 AM   #6 (permalink)
Vehicle: mercedes Benz 221 S600
Pagan has just given you the correct answer, however you may need to turn the wheel from lock to lock at least three times and then the PML will reset
eric242340-old is offline   Reply With Quote
Old 09-11-2007, 12:56 PM   #7 (permalink)
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
When was the last time you change your car battery? If the battery voltage was dropping down under 10 volts at times which is the threshold for the ESP/BAS system according to the Owners Manual.
Pls. complte your PROFILE - Vehicle & Location.
Btw, Welcome to the Board,
-JOE55
JOE55 is offline   Reply With Quote
Old 09-18-2007, 10:17 AM   #8 (permalink)
moaad001's Avatar
I did the reset you like you said, but the messages still appear. These errors only appear when I drive more than 2 miles. I think it might be the steering sensor. Could you go in more detail about the sensors?
Thanks
Old 09-18-2007, 10:57 AM   #9 (permalink)
gregs210's Avatar
Thanks
Hey, moaad001, how long has this been going on?
Old 09-18-2007, 02:52 PM   #10 (permalink)
moaad001's Avatar
It's about a month now. But I don't have any problems with my brakes or something else ... So there is no harm done. Those lights are just bad for the looks of my clusterboard
ESP, BAS & ABS MALFUNCTION tnsr35 R171 SLK Class 11 09-01-2007 11:35 AM
BAS ABS ESP malfunction after tightening loose steering column sdjumin W210 E-Class 0 10-15-2006 06:43 PM
HELP ABS, BAS, ESP Malfunction Detected DGW203 W203 C-Class 6 04-28-2006 09:13 AM
BAS/ESP light warning malfunction on - then it reset and is off???? Michael O W208 CLK Class 4 08-10-2004 01:00 AM
BAS ESP ABS Frank W208 CLK Class 3 08-06-2004 10:41 PM
