Old 08-23-2007, 09:03 AM   #1 (permalink)
Date registered: Sep 2002
Vehicle: 2000 E320S4, 1989 Porsche 911 Cabriolet, 1986 Volvo 760T; 1988 300SE (sold); 1974 240D (sold)
DIY brake advice
I recently did pads and rotors F&R on my 00 4matic wagon, thanks to the helpful pdf on the stickypost. However, something's not quite right.
Front: I cannot get the anti-rattle spring to sit with both ends underneath the wings. I have them where one side is under and one is above and that is enought tension to keep it from falling off, but I have found some pictures and I know that's not right.
Rear: there is obvious play in the right rear inner pad, with nothing to keep tension on it. I have the two pin calipers. I bought the anti-rattle spring for the rear from the dealer and received a grey cruciate shape metal spring. There must be another pin or something that can keep this thing in place. The parts diagrams which are not too helpful show some sort of t-shape pin. I also saw somewhere spacers for the pads. However I cannot picture how it all goes together.
When I step on the brakes I hear the click from the rear, sounds like a camera shutter, and when I am not on the brakes there is a faint whine/squeal coming from somewhere, don't know where.
If anyone has or could take a picture of the rear caliper showing the pins and spring as they should be assembled I would be grateful so I can figure out what if any parts I'm missing. Any advice appreciated too. Thanks in advance.
dr.pitch is offline   Reply With Quote
Old 08-23-2007, 11:10 AM   #2 (permalink)
ohlord's Avatar
Wife's
On the road with her real estate business,and has the wagon,or I would take pics.However someone will chime in.Next time and for future reference to anyone finding this post while trying to do brakes DIY,
Always do one side at a time so you have a reference of how it looks correctv.s. the side you are r/r.
Just a tip
ohlord
"GOT CODES?"
Post this over on mbworld.org and maybe raymond has the parts diagram he can pm you..................or pm him and ask
Or maybe he's lurking someplace on this forum and has pics....
Advice on DIY vs. Non DIY Repair Prochambers W126 S,SE,SEC,SEL,SD,SDL Class 10 08-30-2008 11:58 PM
Brake DIY gregs210 The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 02-09-2007 06:04 PM
DIY Brake Pads johneurostar W211 E-Class 3 12-01-2006 11:24 AM
Front Brake DIY done pcmaher W140 S-Class 6 08-16-2005 03:10 PM
DIY Brake Job TheFunks W124 E,CE,D,TD Class 6 10-25-2004 10:21 AM
