» Site Navigation
» Other Sites
Old 08-09-2007, 10:34 PM   #1 (permalink)
Date registered: Oct 2006
Vehicle: 1983 300D- sold
funny tapping noise
Just today I noticed a funny tapping noise in the engine in my '02 E320 4matic.
I think it just started today. I accidentally stepped on the accelerator while parked and revved up to almost 6000 rpm for a second or two. half hour later I noticed a tapping noise in the motor. It doesn't happen all the time. It stops and starts on its own.
What could it be? I'm hoping it's not a valve. (probably is)
farghenbenzer is offline   Reply With Quote
Old 08-10-2007, 10:52 AM   #2 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Hey, farghenbenzer.
I doubt it's a valve, once they start making noise they generally continue to do so, not coming and going.
Could be a lifter, injectors also sometimes will make noise. Without actually being able to listen to it it's nearly impossible to guess. If you're concerned with it, take it in and get a pro to listen to it.
Good luck and enjoy the ride,
Greg
Old 08-16-2007, 04:07 PM   #3 (permalink)
tapping noise fixed!!
It was a fuel evaporator valve or "mott "valve as they call it. Mercedes fixed it under warranty.
Also, there was some dead pixels in the display where the clock is. Mercedes replaced the entire instrument cluster. Under warranty!!wooohooo!!!!
They also fixed that funny sqeak in the steering wheel. All under warranty.
I figure my bill would have been $1200.00 easy, considering the instrument cluster alone is $1000.00 retail.
Even got a 2007 C280 4matic as a loaner.
Old 08-16-2007, 05:45 PM   #4 (permalink)
gregs210's Avatar
SHAZAM!!
That's great, glad they treated you well and got the car all squared away.
Take care and enjoy the ride,
Greg
2007 e350 sport tapping noise tinkerbell825 W211 E-Class 6 03-06-2007 04:44 PM
Tapping Noise At Front Of Engine BRUCIE BABY W202 C-Class 2 01-10-2007 05:57 AM
Engine tapping/knocking noise tresean1 W202 C-Class 1 01-02-2007 03:46 PM
Tapping Noise osdesierto W203 C-Class 1 11-17-2004 10:07 AM
hard tapping noise when steering at speed graymarket500SEL W126 S,SE,SEC,SEL,SD,SDL Class 0 02-19-2003 10:32 AM
