Old 08-08-2007, 03:50 PM   #1 (permalink)
Date registered: Aug 2007
E320 AC was blowing hot, now quit blowing
Hi everybody,
I have E320, I used to have the AC blowing hot, my wife took it for repair and now AC quits blowing.
the fan turn on but no AC at all. I believe even the hot is gone.
I'm not expert, I just want to know better about the car before trying somebody else to fix it.
whoever can help, please excuse my ignorance in cars and try to give more details. I was reading couple topics here and I couldn't understand too many terms used. sounds I have to learn alots to be able to just hang with you here.
and thank you for any help
David
DavidCohen is offline   Reply With Quote
Old 08-08-2007, 05:52 PM   #2 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Hi, David, and welcome to the forum.
When you have a minute please click the control panel link at the top right of the page and complete your user profile (car/locale) which is helpful.
My first thought would be to return the car to the place that did the (obviously incorrect) repair. If the understanding was that they would fix it, they clearly didn't. (Not blowing hot air is an improvement, but...)
Given your unfamiliarity with automotive AC, a W210 is not the car to learn on. It's far more complex than the typical AC system on most cars, so there are even more possibilities.
If you want just a bit of information, go to the sticky at the top of this W210 forum for DIY and FAQ, then look at the list for the AC diagnosis, that will link you out to the Eclass site for a diagnostic procedure/chart you can run. That will give you some feedback and some useful information. Read through it all until you're comfortable with it before you run the procedure, if you wait too long during it the system resets and you have to start over. Once you have that information you can come back or -- depending on what the info is -- you may have it figured out. One thing to think of is whether the EC light is going off when you press that button and the AC is otherwise "on". If the EC light stays on then that narrows the field.
Take care and enjoy the ride,
Greg
Meister Eckhart
Old 08-08-2007, 06:05 PM   #3 (permalink)
Musikmann's Avatar
Welcome to the forum David!
Don't concern yourself with knowing a lot about your car before hanging with us here. Please remember that all of us were new once, and believe me, I knew about as much as you might right now (probably less) when I first joined.
These MBs are pretty complicated, so just hang in there and you'll be fine.
Old 08-09-2007, 03:02 PM   #4 (permalink)
thank you Greg and Musikmann for replying.
I went do what you said and this is what I have:
01----------37
02----------35
03----------37
04----------37
05----------27
06----------67
07----------11
08----------45
and the Errors
Eb1234
Eb1459
E---FF
and can't exit. I think because of E----FF
I see I'm gonna take Musikmann's advice and hang in here for awhile . I drive
E300 and the A/C doesn't get cold the way he used to. I believe I'm going to do the samething for my car. but you know...! wife first
you all have good day
David
Old 08-11-2007, 01:42 PM   #5 (permalink)
hey you again,
I thought I can do the samething to my E300 but it's old model. how can I know what should I do about the Errors above? is there a website who interprete this or I have just to wait for somebody who had the same Errors to come and answer me here?
I wish I find somebody out there to answer my questions and thank you.
David
Old 08-11-2007, 02:38 PM   #6 (permalink)
Date registered: Nov 2005
Vehicle: 1996 210.020
Or someone with a diagnostic manual.
B1234 - sun sensor (B32)
B1459 - Series interface (K2) connection to instrument cluster (A1)
Ignore B1234. I don't know why B1459 would keep you from getting cold air other than shutting down the compressor. Is the clutch engaging?
Old 08-11-2007, 09:27 PM   #7 (permalink)
Hi Matt.
I get nothing now. let's me make myself clear? it was blowing no cold air before she took it for repair. after that, I get nothing! the whole system doesn't function.
thank you for answering me.
David
Old 08-11-2007, 10:14 PM   #8 (permalink)
I'm not sure that I understand. You get no blower?
If this is the case, I would suspect that your regulator quit and is completely unrelated to any other problems. Put the blower on max and post the current sensor values again, but this time don't stop at #8.
Old 08-21-2007, 03:51 PM   #9 (permalink)
Hello Matt L,
I'm sorry for being unable to answer you early, I was out of town.
this is all what I had about sensors, doing what you asked me to do:
01----------37
02----------45
03----------31
04----------31
05----------20
06----------76
07----------13
08----------50
09----------04
10----------6.0
11----------3.3
12----------4.1
20----------0.0
21----------0.7
22----------0.0
23----------0.0
24----------13.3
40----------71
41----------36
42----------72
43----------136
and the same erreurs like above.
Eb1234
Eb1459
E---FF
by the way, some of the sensors change the numbers with time. after I finished the test, I kept pushing auto to see them one more time. I found sensors 3 to 8 changed to:
03----------40
04----------39
05----------27
06----------86
07----------12
08----------47.
waiting for any help I can get and thank you
David
Old 08-21-2007, 04:32 PM   #10 (permalink)
If you have no airflow, it's time to check the blower regulator.
ac blowing hot air on the side vents?!? HELP, its hot out here.. DCBreed W140 S-Class 6 06-19-2007 12:18 PM
Vents blowing hot air Hoppy R/C107 SL/SLC Class 3 09-07-2005 01:27 PM
hot air blowing from vents 90secowner W201 190E, D-Class 7 03-14-2005 07:17 PM
AC Blowing HOT Air, please help. atif W123 E,CE,D,CD,TD,TE Class 2 09-04-2004 09:43 AM
A/C BLOWING HOT AIR!!!!!!!!!!!! BIZYGUY W140 S-Class 7 08-05-2004 12:21 PM
