Old 07-31-2007, 04:31 PM   #1 (permalink)
Date registered: Jul 2007
Vehicle: 2000 E430
Send a message via AIM to boostted
Wheel size question
Hey guys, Im about to pick up a E430 tomorrow and I was looking at some wheels. I was wondering if wheels in these sizes would fit
19x8.5 et 39 - 225/35/19 Front
19x9.5 et 42 - 245/35/19 Rear
THanks
boostted is offline   Reply With Quote
Old 07-31-2007, 04:59 PM   #2 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
Hey, boostted, welcome to the forum. When you get a minute please update your profile re: car and locale.
Hopefully one of the other folks with 19s can confirm/deny, but you should have no problems on the back. The front may be tight, you may need a 5mm spacer.
If you're sourcing the wheels from a reputable source, make them put their reputation on the line and assure you of a no hassle refund or return if they don't fit. Even if someone on here says you're okay, what's the recourse if not?
Take care and enjoy the ride,
Greg
Meister Eckhart
Old 07-31-2007, 05:33 PM   #3 (permalink)
it also depends on the year/make/model of your benz... but if you have a w210 or w211... then those sizes will definitely fit...
UnitedBenz is offline   Reply With Quote
Old 08-01-2007, 02:28 AM   #4 (permalink)
Vehicle: 2000 E430
its a 2000 so I believe its a W210
Old 08-01-2007, 02:29 AM   #5 (permalink)
Vehicle: 2000 E430
Greg
I will update my profile as soon as I pick up the car tomorrow afternoon
As far as reputable source, I am buying them used so no return policy there, but I will be sure to test fit them before i buy them. I just wanted to see if they have a chance of even fitting so I dont have to waste my time.
Old 08-11-2007, 11:06 PM   #6 (permalink)
Date registered: Apr 2007
I have 18's on mine and it is tight especially when you go with a wider tire as well. The question is not just will they fit but what type of effect will they have on your suspension. I'm afraid the that larger wheel/tire package will cause expensive problems down the road.
armymedic01 is offline   Reply With Quote
Wheel Size Upgrade Question Tom4697 W203 C-Class 4 03-28-2007 05:09 PM
wheel size question SikSlk99 R170 SLK Class 7 12-03-2006 12:38 AM
Wheel and tire size question Groundpounder03 W220 S-Class 15 11-16-2005 10:34 AM
Final wheel size question... vballbach R170 SLK Class 3 08-25-2004 01:46 PM
Question regarding wheel size and performance.... kenny R170 SLK Class 15 04-23-2002 09:14 AM
