» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W210 E-Class
Old 12-03-2007, 08:07 PM   #21 (permalink)
ohlord's Avatar
Vehicle: 1999E320 Wagon,2000 E 320 Wagon, 2000 E 55 powered wagon MGB Track/Rally 94 Subaru
they will
trip a cel and then you either replace them if over 80k miles just because it is a part of maint like changing oil,or you confirm the fault by back probing with a multimeter or a real time scanner at a shop or an autotap.com unit if you have one in your home shop.
Not a hard diy if you are careful with the wires and use the correct socket and pull them when the pipes are still warm,not hot they burn but warm makes it easier to turn them out.And always use the supplied antiseize or if not supplied the special o2 sensor anti seize the plain stuff will bung up a o2 sensor if it gets onto the probe.
ohlord is online now   Reply With Quote
Old 12-04-2007, 11:08 PM   #22 (permalink)
Kobus's Avatar
Date registered: Apr 2007
Vehicle: 2001 SLK 320(111K Miles), 2002 E320 Special Edition(122K Miles)
I'll just wait for a CEL and code to come on before changing the failed one. They are very easy to get to, so I'll just changed the failed one. I've checked mine with my real-time scanner and they are still perfect at 93,000 miles. But I mostly do long trips so the exhaust and sensors get warmed up properly on every trip. On my 190E I had 145,000 miles on the O2 sensor without replacing. Strangely enough, the service instructions for that car said to replace the O2 sensor ONCE at 80,000 miles, and the O2 sensor light came on at 81,000 miles. The replacement lasted for 145,000 miles until the car was written off at 226,000 miles, passing a smog test 2 week prior to its demise.
Kobus is offline   Reply With Quote
Old 12-05-2007, 04:41 AM   #23 (permalink)
fju2112's Avatar
Date registered: Nov 2005
Vehicle: 2002 E320 4Matic, 107K miles as of Jan 2009
good stuff kobus! i'm surprised they're so easy to do though...i guess for me the issue is getting it lifted and supported properly before i can do the work.
2002 E320 4matic sedan, black on beige ("sport" package - bird's eye maple trim, 17" sport rims), 108K miles
RIP: 2000 E430 4Matic fully loaded - totaled 12/9/2006
Wife's car: 2000 Lexus ES300, Platinum Edition, 98K miles
http://drivingenthusiast.blogspot.com
fju2112 is offline   Reply With Quote
Old 12-05-2007, 10:16 AM   #24 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
FJ, you know I'm a big proponent of DIY...however, when the time comes for my car, then assuming after inspection that the rest of the exhaust system is in good condition, I'll be buying aftermarkets and taking them to a muffler shop to be welded in. You can do both in this manner -- and replace all four O2 sensors -- for less than the cost of doing one cat with the stock setup...and you only have to lift the car enough to inspect it. (FWIW I do have a relatively green mind; the aftermarket units retain the proper specs and emission requirements, I wouldn't want to turn my ULEV vehicle into a polluter. Part of this is not just cost; if I rip out an entire side and the only bad part is the cat, then the rest must be recycled, but re-use is better than recycling any day.)
JMHO, I'll never impugn anyone for retaining the factory setup.
Take care and enjoy the ride,
Greg
If we ever forget that we are one nation under God, then we will be a nation gone under.
Ronald Reagan
Old 12-05-2007, 10:18 AM   #25 (permalink)
fju2112's Avatar
i'm just wondering if a muffler shop will even do that? some mechanics might balk at that, saying they're not going to use your parts and then weld something together, then be responsible if it doesn't work, you know?
so the "universal cats" are much smaller pieces than we see in the DIY?
as for o2 sensor replacement, is that something one can do easily enough with just wal-mart ramps? that's all i really have for lift...that, the jack, and wood blocks!
Old 12-05-2007, 11:07 PM   #26 (permalink)
Kobus's Avatar
The upstream ones (before the cat) you replace from then engine compartment. The downstream ones - well that depends on your girth . You can actually slide in underneath and remove them without lifting the car. Or if you don't mind working outside, drive the wheels one one side on the pavement. Any ramps will work fine.
Old 10-09-2008, 12:43 PM   #27 (permalink)
Date registered: Nov 2006
I have 87K on my E320 wagon and live in the OC. I had one cat replaced under warranty and the other just started rattling. Couldn't afford to have the dealer replace the cat $1,200 P&L and the good guy price! How many O2 sensors do I need w/ 80K mi? Where should I buy them and a universal cat? Do you know of a welding shop in the OC or South Bay that can do the work reasonably?
Thanks in advance for your help.
KL
SCalum is offline   Reply With Quote
Old 10-09-2008, 01:05 PM   #28 (permalink)
fju2112's Avatar
You shouldn't need any O2 sensors replaced with a universal cat; I know I didn't. You can replace O2 sensors at 100K, that's what ohlord's recommendation is, or you can wait till the system screams at you for having old O2 sensors after 100K miles
Old 01-20-2009, 08:10 PM   #29 (permalink)
Date registered: Feb 2008
Vehicle: 2001 E320, 4MATIC
Great instructions. Much that I would like to take this venture...I have to leave this one for the dealer.
UVirk01 is offline   Reply With Quote
Old 01-20-2009, 08:25 PM   #30 (permalink)
celm's Avatar
Date registered: Jan 2009
Vehicle: 2007 BMW X5,2001 Benz E320,1995 Toyota Aristo
Send a message via AIM to celm
so what is the warranty on the cat,how many years and mileage
celm is offline   Reply With Quote
I LIVE in California and need to replace my Catalytic Converter DETANE W210 E-Class 3 02-09-2007 11:05 AM
Catalytic converter majorkahuna R129 SL Class 2 06-30-2006 07:42 AM
Question on how to replace catalytic converter on 500 sec q921 W126 S,SE,SEC,SEL,SD,SDL Class 2 10-26-2003 03:41 PM
Catalytic Converter dt77 W163 M-Class 0 02-10-2003 09:21 PM
If I replace the catalytic converter... Jordan R170 SLK Class 5 09-19-2002 04:13 PM
