Old 07-27-2007, 11:17 AM   #1 (permalink)
VeloFemme's Avatar
Date registered: Aug 2006
Vehicle: 1997 E320
Send a message via Yahoo to VeloFemme
Question Oil Service Indicator - How to Turn Off When Service Manual Doesn't Work?
We just did an oil change on a 1997 E320 (10K, synthetic oil). When we went to reset the service indicator light, we can't get it to shut off. We tried the steps in the manual, we also checked ALLDATA, and their recommendations did not work. In addition, we cannot ge the "service wrench" to appear on the screen.
Anyone else out there have this problem, and did you find a solution?
Thanks!
VeloFemme is offline   Reply With Quote
Old 08-07-2007, 12:44 AM   #2 (permalink)
Date registered: Jul 2007
Vehicle: W210 '97
Got this from another forum:
1) Key on (position 2, all idiot lights come on, engine NOT running), within 4 seconds press the "0" twice (The present value is displayed)
2) Within 10 seconds turn the key back to the 0 position
3) Press and hold the "0" button while turning the key to position 2 again (The present value is displayed again), continue to hold the "0" button for 10 more seconds. You should hear a beep and the counter will go back to 15000 km.
4) Release the "0" button
p/s make sure your doors are closed. Hope this helps you.
ikanoren is offline   Reply With Quote
Old 08-07-2007, 07:11 AM   #3 (permalink)
'91 300CE's Avatar
Date registered: Jul 2006
Vehicle: 2000 C230K and 2002 ML320
It should read 10000 Miles as he is in the US. Don't want him to think something is wrong when it reads 10000 not 15000.
And yes, it is vital that your doors are closed and that you stand on your head and hold your breath, while praying... LOL... but really, you do need to have the doors closed.
2000 C230K -- Travertine Beige Metallic
2002 ML320 -- Alabaster White
2002 ML320 -- Brilliant Silver - Dad's
1991 300CE -- Blue Black Metallic -- 129,000 miles -- Sold
1981 300SD -- Classic White -- 190,000 miles -- Sold
1977 240D -- Over 300k miles (Wrecked) -- My 1st car
'91 300CE is offline   Reply With Quote
Old 08-07-2007, 08:07 AM   #4 (permalink)
slybydesignw210's Avatar
Date registered: Jan 2007
Vehicle: Pearl White 1994 Q45T
Its funny theres a post for this, I went to the dealer yesterday for the same reason. He was extremely helpful. He had to make sure the door was closed and hold 0 then turning the key back worked like a charm.
He also kept trying to press the R button and said something to the effect that it worked too. Good luck.
slybydesignw210 is offline   Reply With Quote
Old 08-07-2007, 08:53 AM   #5 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/320cdi ML320/55
Older models require starting the procedure in "sleep mode" (all lights and displays off).
That is often overlooked. On 2001 ML I reset the meter with door open and without sleep mode.
VeloFemme says, that the "service wrench" doesn't appear. Don't know if 97 had that option
Kajtek1 is online now   Reply With Quote
Reseting the flexible service system. Does the service manual lie once again? wallywalt R170 SLK Class 0 09-09-2005 11:02 AM
Oil change / Service indicator a204600 R170 SLK Class 4 01-04-2005 04:44 PM
HELP!!! I lost my service manual and I need a diagram so I can finish my oil change!! Geeky1 W126 S,SE,SEC,SEL,SD,SDL Class 5 03-28-2004 07:20 PM
Problems getting W124 Service Manual CD to work Guest (MBNZ) W124 E,CE,D,TD Class 7 07-27-2002 09:54 AM
oil change intervals per clk service indicator shy W208 CLK Class 5 01-07-2002 09:33 AM
