Old 07-25-2007, 12:37 AM   #1 (permalink)
.::Ğї::.'s Avatar
Vehicle: Mercedes Benz E320
Send a message via MSN to .::Ğї::. Send a message via Yahoo to .::Ğї::. Send a message via Skype™ to .::Ğї::.
is it available to automatically close the window when locking the car?
hello!
I'm is it available automatically to close the window when i lock the car?
regards Gi
.::Ğї::. is offline   Reply With Quote
Old 07-25-2007, 01:13 AM   #2 (permalink)
ohlord's Avatar
Smile yes
hold the lock button for a few seconds after the locks close and it will close the windows and the sun roof,hold the open button the same amount time and it will open the windows and sun roof before you get in on a hot day.
ohlord
"GOT CODES?"
Old 07-25-2007, 01:16 AM   #3 (permalink)
.::Ğї::.'s Avatar
i tried but it doesnot work i have 97 E320
Old 07-25-2007, 07:42 AM   #4 (permalink)
illest's Avatar
Date registered: Sep 2006
Vehicle: 98 320
On mine (98 e320) you have to aim the smart key at the sensor on the door handle to do this.
www.razoredgestudios.com
illest is offline   Reply With Quote
Old 07-25-2007, 09:47 AM   #5 (permalink)
gregs210's Avatar
Vehicle: '01-E320 & 02-ST2
^^^^ True, dat.
You have to be fairly close (several feet) and pretty aim the remote in-line with the IR sensor in one of the front passenger door handles, hold the lock button down on the remote (not just press/release) and it will lock the car, then close the sunroof and windows.
Take care and enjoy the ride,
Greg
Meister Eckhart
Old 07-25-2007, 10:40 AM   #6 (permalink)
JOE55's Avatar
Date registered: Nov 2004
Vehicle: E55 ///AMG
On mine I can do it even on the passenger side, I'll show it to you bro on our meet
JOE55 is offline   Reply With Quote
Old 07-25-2007, 10:58 AM   #7 (permalink)
Kajtek1's Avatar
Vehicle: E300DT/320cdi ML320/55
97 model desn't have smart key.
It started in 98 with the option.
Kajtek1 is online now   Reply With Quote
Old 07-25-2007, 11:32 AM   #8 (permalink)
reyna7's Avatar
Vehicle: 2000 E430 Sport
Make sure your smart key battery is good. I replaced mine w/ a new one after noticing diminished performance and it worked like a charm.
Still won’t work from long distances but overall performance definitely improved.
reyna7 is offline   Reply With Quote
Old 07-25-2007, 01:28 PM   #9 (permalink)
slybydesignw210's Avatar
Date registered: Jan 2007
Vehicle: Pearl White 1994 Q45T
I use to be able to do it and now even with a new battery it wont work for me.......
slybydesignw210 is offline   Reply With Quote
Old 07-25-2007, 01:38 PM   #10 (permalink)
E-Class Owner's Avatar
Vehicle: 1997 Mercedes Benz E420
I tried this feature on my '97 E420 and it works on both the driver's door and trunk IR receivers. One thing I did notice, is that you must keep the button on the key depressed until the windows are completely closed; if you stop midway, you will have to unlock the car and start over...
Good luck.
E-Class Owner is offline   Reply With Quote
central locking/window help required please northants124 W124 E,CE,D,TD Class 2 07-30-2006 04:08 AM
Fog lamp turns on / off when open / close the car? Mercedes_Calle W140 S-Class 5 06-13-2006 09:34 AM
300ce auto window close conleycrew3 W124 E,CE,D,TD Class 3 11-11-2005 06:02 AM
Help!! Driver side window won't close (go up)! =( G-Benz W163 M-Class 5 10-19-2003 01:04 AM
280CE Vacuum Central Locking and Back Window Jam Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 3 04-06-2002 10:51 PM
